BIKELAND > FORUMS > ZX-14.com > Thread: Busa spring???? NEW TOPIC NEW POLL POST REPLY
Bawls
re-learning to ride
posted November 08, 2009 04:11 PM
Busa spring????
Which year model Busa spring are you guys running? Since racetech has completely fucked me over i'm going to have to just find a busa spring. Will any year model work, or is it only the gen2? Also, what else do i need to get in order to make it work?
thanks for the Info guys.
Chad
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
posted November 08, 2009 04:13 PM        Edited By: Shane661 on 9 Nov 2009 00:14
Are you a pretty light guy? I would think you could get away with the stock shock at 63".
I had no problem with it last year at 230+ lbs. suited, but I was only running high 1.4's at best...mostly 1.5's.
06redzx14
posted November 08, 2009 04:45 PM
08
Bawls
re-learning to ride
posted November 08, 2009 04:48 PM
i'm 168-170 lbs. Stock 07 fuel pump though so i'm afraid of hitting the swingarm. i do still need to stiffen my stock spring and set my screw though. a friend who is 190 lbs sat on my bike and bottomed it out so i know that the shock isn't set lol
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
posted November 08, 2009 04:50 PM
I had the standard 07 pump on mine as well. It is obviously going to depend on how low you have the dogbones set. Mine had the stock fender and the tire kissed that before the pump came in contact.
Lucky14
posted November 08, 2009 05:30 PM
Talk to Wheelie.
He went to the Busa spring, didn't like it, so put the stock 14 spring back on.
That's the story as I remember it .......................
Bawls
re-learning to ride
posted November 08, 2009 06:36 PM
Slammed on the bottom hole, 1" in the front. Full tiger under tail. The only thing that I'm worried about is bottoming the swingarm out on the fuel pump. Eventually I'll talk the wife into letting me buy an 08 fuel pump, but until then I get to work with what I've got lol. Any tips on the stock shock with stock spring?
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
kawasakijockey
posted November 08, 2009 07:05 PM
I put an 08 spring on and I weigh 210 with 64.5 wb. At full soft setting the busa spring is a lot stiffer than the hardest setting of the 14 stock spring.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
the14thninja
Show and Go
posted November 08, 2009 08:15 PM
I used the 08 spring and I'm stretched 8 inches over and i weigh 230 lbs and it really made a difference, its alot stiffer.
I live to ride and ride to live
gilberjj
Friend of Fast
posted November 08, 2009 08:43 PM
I've heard that the gen 1 busa has a little softer spring. I'm unaware if it is compatible, but it is harder then the 14 spring, and softer then the gen 2
Newf14
2007 ZX1400
posted November 09, 2009 07:51 AM
I am 215 lbs give or take suited I have a Busa spring ready to go in but I still never really tryed it with the stock 14 spring and until I do it aint goin in.
Newf14
madnessracing
Vmax and Busa Beater
posted November 10, 2009 05:52 PM        Edited By: madnessracing on 11 Nov 2009 01:52
If you're over 230lbs is good for you!!
Shorty's Performance
Team Madness Racing
bigwil
06 zx 14 turbo stage 3
posted November 11, 2009 06:56 AM
im running the 08 spring with a litz revalve stock shock @ 68 inch wheel base
im 230 and sunday i got my fiirst 1.38 60 ft
but i dont think i would lk it on a short bike
bigwil// going fast aint easy so turbo it
Bawls
re-learning to ride
posted November 11, 2009 09:01 AM
I'm sitting at racetech right now getting my spring done. I just got lectured about how my lowering bones and stock shock are garbage and that it's not going to work so I need to have them revalve, respring, and shorten my shock instead. Holy fuck just put the spring on like I'm paying you to do and let me worry about it myself lol.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
0.23497104644775 seconds processing time
