BIKELAND > FORUMS > ZX-14.com > Thread: Dash shift light NEW TOPIC NEW POLL POST REPLY
Douglas Home
posted October 28, 2009 08:57 PM
Dash shift light
Does anyone know if the dash shiftlight is on true coil RPM or tacho RPM?
What do you guys have it set at?
Also what is the difference between coil & tacho RPM?
Had problems with my shift light so removed it and have a T/N/T on Friday night so
just got to sort something out .
Thanks guys
Doug Mackay Australia
Douglas Home
posted October 29, 2009 12:59 AM
If you answer this question I personally guarantee you a PB at your next race!!!
BobC
posted October 29, 2009 01:13 AM        Edited By: BobC on 29 Oct 2009 09:16
I don't use the Kawasaki shiftlight, it's too dim in bright sunshine and in the wrong place, it needs to be in your eyeline. Most riders fit an aftermarket one such as MSD.
The difference between coil rpm and tacho rpm is because the analogue instrument over-reads. Anyone who has gone to the engine rev-limiter will have seen around 11,300 or so on the tacho. On a dyno the real rev-limiter rpm from the dynojet's computer screen will be more like 10,800rpm, so the tacho is about +5% optimistic.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
TooHype
Go Hard or Go Home !!
posted October 29, 2009 01:26 AM
With that said, what would be the best setting for the dash shift light
Bluebyyou
Gettin My Curve On
posted October 29, 2009 02:59 AM
The O.E.M. shift light is useless unless you concentrate on it instead of riding, I agree with BobC, too dim and positioned all wrong. It's easy to miss and hit rev limiter when going supersonic.
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
posted October 29, 2009 05:03 AM
i got mine set at 11,200 and you gotta be ready to hit the button! especially that 1-2 shift. but i hate the stock shift light. just cant afford a new one.
Douglas Home
posted October 29, 2009 10:52 AM
Thanks guys and gues what , only three days to go till I can ride on the streets again.
Time to put the mirrirs back on!!!
INTIMIDA2OR
RED rider!
posted October 29, 2009 03:54 PM
I really can only use the stage light. The shift light is too small and dim to see when the warp drives kick in.
Kawi should have made the led in both lights those super bright clear lense bulbs instead of the fogged opaque ones that are in there.
'06 Passion Red ZX-14
*Lee*
INTIMIDA2OR
RED rider!
posted October 29, 2009 04:15 PM
My shift light is set at 10,500 even though I never can use it
*Lee*
0.34387493133545 seconds processing time
