BIKELAND > FORUMS > ZX-14.com > Thread: How much Mr9 ? NEW TOPIC NEW POLL POST REPLY
BLK ICE
posted October 20, 2009 11:41 AM
How much Mr9 ?
What is the less amount of gas do you think will make 6 1/8 mile passes?
Thanks for Replys,
posted October 20, 2009 11:57 AM
I could run 6 1/8 mile runs on a 1/2 gallon of MR9 ... But you need at least a gallon in the tank to start off with... I never run less than 1 and 1/2 gallons of fuel in my bike but i guess you could run a bit less and not starve the pump ..
BLK ICE
posted October 20, 2009 12:07 PM
Thanks Smokin.
posted October 20, 2009 02:15 PM
You are very welcome sir ...
14nooby
posted October 20, 2009 02:25 PM
I use a 1 quart funnel with an on off spout. I start off with 5 quarts and then after each pass I add 1 quart. I keep it this close because of draining it when I get home.
Bently
2012 14r In Blue and no Mods!
posted October 20, 2009 02:33 PM
That's why I've never messed with I'm to darn lazy to drain it when I get home.
BLK ICE
posted October 20, 2009 02:52 PM
Thanks for the info.14nooby.
posted October 20, 2009 02:57 PM
How are u guys draining the tank?
posted October 20, 2009 03:16 PM
I pull the tank and remove the fuel pump and dump out the fuel ... I'm pretty quick at it ...lol..
BLK ICE
posted October 20, 2009 03:19 PM
+1, but I'm pretty slow at it.
14nooby
I just pull the hose off of the fuel pump (the one with the red clilp) then I cycle the key on and off slowly until its empty. Then I run the bike until it dies, which gets out all remaining MR9. I put in about 1/4 gallon of pump gas and run the bike until I smell pump gas coming out of the exhaust. MR9 is lethal to your fuel injectors and valves if left in the bike. I saw a guy at the track pouring rust out of his Busa tank because MR9 ate the coating in his gas tank off.
Pretty Fast
posted October 20, 2009 06:20 PM
Smoke, do you replace the pump gasket after each drain?
posted October 20, 2009 06:59 PM
it's an Oring not gasket ... I reused it , no need to replace it ..
Pretty Fast
posted October 20, 2009 07:16 PM
Thanks Smoke!
gilberjj
Friend of Fast
posted October 20, 2009 08:49 PM
Why pull off the pump? The quick disconnect is easier isn't it?
14nooby
posted October 21, 2009 04:10 AM
Gilbjj, I have emptied my tank both ways and find it a bit more time consuming to remove the pump. I don't like disconnecting the electrical connectors or removing the pump. I also drain it with 3/8 hose back into the MR9 can......I can't afford to waste a drop of it.
gilberjj
Friend of Fast
posted October 21, 2009 03:05 PM
I believe it..... isn't it like $25 a gallon? I'll be converting my race bike to e85 later next year once I get my times dialed in. I want to see if that cheap fuel will make more power. I think the real advantage will be with a wet nitrous system installed. I could run as much nitrous as the motor would hold and e85 will never pre-ignite. There will be a couple issues though, like getting it tuned, and having the correct size fuel nozzles (you have to use about 30% more fuel).
14nooby
posted October 21, 2009 03:31 PM
Its about $25-30 a gallon...........Good luck with your E85 conversion. I know nothing about that stuff.
posted October 21, 2009 03:37 PM
Why would you switch to e85?? And it takes 20-30percent more fuel to equal the same as reg unleaded? That sounds like a bunch of work for nothing.
gilberjj
Friend of Fast
posted October 22, 2009 01:15 PM
It makes more power being the biggest reason. There are several all motor hondas in my area who gained 2 tenths (11.7-11.5 second cars) by ONLY switching to e85 and tuning for the same a/f ratio. These cars make it to every test n tune possible, so it's not just a fluke either. Do a little research, e85 makes a touch more power then pump.
PLUS: When I eventually run nitrous, I can spray to my hearts delight. e85 is about 110 octane.
PLUS: e85 runs very cool, and while I've never had a problem with my bike overheating, some people have had that problem.
4Racing
VP Race Fuel Expert
posted October 30, 2009 10:39 PM
MR9 is great on motor and only $106 for a five gallon can. MRXO1 is good on motor and great on spray for only $100 for a five gallon can. Both fuels should be stored sealed and cool for best performance.
0.22259712219238 seconds processing time
