BIKELAND > FORUMS > ZX-14.com > Thread: Water pump mod NEW TOPIC NEW POLL POST REPLY
08green
posted October 20, 2009 06:58 AM
Water pump mod
Has anyone done an electric water pump instead of the driven stock one. Buddy of mine say its good for 7-10hp when you take it all apart and sheer off the fins. Have you ever tried to run in water? RCC turbos offers them...not cheap tho..about $300..
What you think...
2004 ZX10
2008 ZX14
starchild
posted October 20, 2009 08:51 AM
anymore info on this mod? kind of confused on shearing the fins--how would it circulate the coolant? i have heard of the electric pump giving more horse power over the stock, but only in cars. i'd be really interested in this mod.
jay
kawasakijockey
posted October 20, 2009 09:02 AM
7-10 hp??? No friggin way....
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted October 20, 2009 09:04 AM        Edited By: Shane661 on 20 Oct 2009 17:05
Electric pump primer:
http://www.superchevy.com/technical/engines_drivetrain/accessories_electronics/0408sc_pump/index.html
Considering it is apparently only worth 6 hp on a big v8, I doubt you will see 7-10 on the bike. Maybe someone else here has experience with the pumps in a bike application?
posted October 20, 2009 11:14 AM
I have done it on my cars ...My 63 super stock car picked up a soild tenth going to a electric water pump ..I was very suprized ...
08green
posted October 20, 2009 11:52 AM
Pull your water pump apart and try and turn it... you'll see what im talkin about.. then imagine it submerged in water/coolant trying to move it..most V8's dont rev to 11K either..
Its mostly there for reliability.. much simpler for a mechanical pump, dont have to worry about it ever going out and overheating the motor. Could be a good option if your searching for every HP to free up..
Then buy your self a light of some sort to wire into a hot wire from the pump so you'll know if it ever goes out, pumps NOT on..
2004 ZX10
2008 ZX14
TurboBike
posted October 21, 2009 04:59 PM
The weaker the engine the more you will gain when removing parasitic drag.
RACE WHAT YOU BRUNG AND HOPE YOU BRUNG ENUFF
posted October 21, 2009 05:45 PM
That's a good idea about running a small light!
dcjens
Wet side of Washington
posted October 21, 2009 07:05 PM
Interesting! After reading Shane's link and looking at the pump in the manual, seems simple to fab an electric motor/ impeller to a cover plate (in theory). OR how about cutting down the stock impeller blade size slightly, keeping it mechanical? great food for thought! Bravo!
Black 06
posted October 21, 2009 09:24 PM        Edited By: dubious on 22 Oct 2009 05:27
Do not randomly change the dynamics of the stock pump. It is centrifugal and by design velocity in the volute is converted to pressure. Reducing impeller size and increasing the clearances will have exponential changes in flow, ...reduction that is.
Sizing an appropriate electric pump would be much more suitable.
In the dirt bike world I have often found it beneficiary to clean up sharp edges in the coolant system,
In respect to the pump, one must be very careful not to change the flow characteristics, and dimensions of the discharge and body of the volute, and impeller for reasons described above.
Dirt bikes have very small cooling systems, no fans, and therefor it is very desirable to make the coolant system more efficient in respect to flow ( less hydraulic resistance= less energy required -parasitic loss-as well)
better cooling and more HP !
0.28088808059692 seconds processing time
