BIKELAND > FORUMS > ZX-14.com > Thread: Ground clearance NEW TOPIC NEW POLL POST REPLY
icarus
posted September 25, 2009 04:44 PM
Ground clearance
Who is running a sidewinder exhaust and an Adams pan? How much clearance do you
have? Also, how much did you lower the front? I'm trying to choose between a Ti-Winder
with a 1.5 inch pan and standard sidewinder with a 2 inch pan. The guys at Brock's said
the Ti-Winder has about 1 inch more clearance than their regular sidewinder.
This all came to mind when I landed a gonzo power wheelie and cracked my pan and
flattened my header tubes last Saturday at the track. I had the stock pan with a machined
bolt in it and an AH exhaust.
Thanks...
8.820 @ 161.05
kaw-rick
posted September 25, 2009 05:02 PM
You will have plenty of clearance with tiwinder/sidewinder, adams pan combo. Your stock suspension (shock pivot) will be the lowest point after you get that combo. think im down like 1.5 in the forks. Still have 3 inch ground clearance, and i have a stock (reworked) adams pan. I like it bcuz it holds mor oil. With the billet pan u would have more.
icarus
posted September 25, 2009 05:20 PM
Kaw-Rick, thanks for the reply. I guess the only issue I have is dropping the extra money
for a Ti-Winder at this time.
8.820 @ 161.05
posted September 26, 2009 05:12 AM
How far are your forks slid up in the triples?
icarus
posted September 28, 2009 03:50 PM
1 inch right now. Then strapped at track.
8.820 @ 161.05
0.21860599517822 seconds processing time
