BIKELAND > FORUMS > ZX-14.com > Thread: The Flysholder removed ?? NEW TOPIC NEW POLL POST REPLY
Axel from Germany
posted September 18, 2009 04:53 AM
Hello,
I removed the Flys.
If one gains even more power if the holder be removed to?
Axel
BobC
posted September 18, 2009 04:58 AM
Do you mean remove the shaft too Axel?
There is a position sensor on the end of it, so best to leave it alone or you will get error codes.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
kawasakijockey
posted September 18, 2009 05:11 AM
What he said. Dont mess with it!
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
Axel from Germany
posted September 18, 2009 05:25 AM        Edited By: Axel from Germany on 18 Sep 2009 13:36
Yes i mean the Schaft
I believe that the shaft impede airflow. I want to remove only the shaft does not move the engine of the shaft.
Sorry for my English.
[URL=http://img30.imageshack.us/i/14build702.jpg/][/URL]
Sticks_n_Stones
posted September 18, 2009 06:26 AM
IMO the only thing I would do to it if you felt you needed that additional airflow would be to take the shaft out and grind it down to a 1/16" oval then reinstall. Guys have tried to remove it and ran into nothing but trouble trying to get that stupid sensor attached to the shaft to stop throwing trouble codes.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
Axel from Germany
posted September 18, 2009 06:37 AM
Thank you for this information, That is a very good idea.
johnbull
posted September 18, 2009 09:18 AM
I have had the shaft removed for some time now on my engine. It works well and is making good power. The only difference is that my engine is in a racing car & I dont have the standard dash so I dont get errors on it. Regarding the sensor, I stuck mine fully open so that it permenantly reads fully open flies.
John Bul Racing. Malta.
INTIMIDA2OR
RED rider!
posted September 18, 2009 02:30 PM
Ahh lucky devil! If we tried to do that alls we get is a flashing FI ERROR rendering our dash useless!
'06 Passion Red ZX-14
*Lee*
Axel from Germany
posted September 20, 2009 11:31 PM
do you have also the engine of the shaft moves away?
Axe
johnbull
posted September 21, 2009 02:13 AM
Yes the shaft motor is removed and diconnected.
What other people have done is remove the shaft from the throttle bodies but couple the secondary TPS to the stepper motor so that the ECU still thinks that everythibg is in place.
Axel from Germany
posted September 21, 2009 05:33 AM        Edited By: Axel from Germany on 21 Sep 2009 13:35
Axel from Germany
posted September 21, 2009 05:35 AM        Edited By: Axel from Germany on 21 Sep 2009 13:37
You removed the stepper motor, and no problem ?
That surprises me
rich s
posted September 21, 2009 06:05 AM
There is still a shft and plates on the primaries so I don't see removing the shaft on the secondaries being any benefit at all.
Axel from Germany
posted September 21, 2009 06:25 AM
Yes that's right, because I want to install the Factorypro stacks, it is not much more work.
posted September 21, 2009 12:30 PM
I'd leave them alone, can't be that much gain from it..
0.24529099464417 seconds processing time
