BIKELAND > FORUMS > ZX-14.com > Thread: shock NEW TOPIC NEW POLL POST REPLY
JR
drag racing
posted September 01, 2009 08:54 AM
shock
hey guys whats the easy way to adjust my shock the spring . im suppose to go up or down with the adjustments. thanks
08 zx 14 lowered, straped in the
front, strecth 65, air shifter, pigs
windshiel, carbon fiber frame
sliders, full 2brother exhaust.
  Ignore this member    Click here to visit JR's homepage.
posted September 01, 2009 06:09 PM
I took mine completely out. Really easy to take out. one bolt on top, one on bottom.
I don't know if its the "correct" way but I put bike on front and rear stands and put a jack under the rear of the oil pan and jacked until the pressure was off the bolts holding the shock in.
Take one of your lowering links off and the shock falls right out
The last time I done it I had a set of spring compressors and compressed the spring with them and then tapped the nuts at top of spring and tightened it until there were ab 3 threads left. Took spring compressors off and tada! Put shock back in. I think it really helped the bike launching bc I lowered it quite a bit more and dosent scrub the undertail.
TooHype
Go Hard or Go Home !!
posted September 02, 2009 03:53 AM
I recently picked up a 09' Busa spring, I don't think I'll have a problem taking the shock off the bike but was have been wondering how to get the stock spring off the shock. Any directions would be appreciated.
posted September 02, 2009 04:15 AM
There's a round piece at the bottom of the shock that the bottom of the spring sets on. You have to get the pressure off the piece (only way I see is compress the spring) and it has a slit in it. Take it off and exchange springs. wheelie has done it before, maybe he will chime in and help more than I did
JR
drag racing
posted September 02, 2009 08:47 AM
shock came out easy. need help adjusting the two nut was gonna buy a spanner tool . but if i do compress the spring it would be easyer. thanks
1badvespa1400cc
power junkie
posted September 02, 2009 10:20 AM
Hey wheelie I am trying the same thing,got the old spring out of the 14 scock but cant get the busa spring out,do they make a small spring compressor?
Just another foeteen!!!!!
AcadianaZX
Advertiser
posted September 02, 2009 10:44 PM
Check out Race Tech. I use the one that bolts to the eye on the shock, with the long lever arm to compress the spring. Works well in the vice. I never worked with a BUSA shock. I'm assuming the you can't fully loosen the spring on that one to slide the collar out like the 14. Hope looking at the Race Tech compressor gives some insight. Also I've seen somewhere that someone made one with all thread rods and some plate. A smaller set like the automotive ones would be nice. If someone has found some hopefully they post where to get get them.
0.23553204536438 seconds processing time
