BIKELAND > FORUMS > ZX-14.com > Thread: Flies out finally!!! NEW TOPIC NEW POLL POST REPLY
rich s
posted August 25, 2009 05:13 PM
My PCIII came today so I thought I would pull the flies to see what all the hype is about. Bike is an '07. Had 2 screws that would not come out but did not panic and searched the archives. Found a tip about a long needle nose with a bent end. Worked awesome!!! Put everything back together and took her for a ride. Holy Mother that is incredible Still don't have the PCIII installed but I filled out my Brocks form and hopefully the map is emailed in a few days.
Between this and the suspension adjustments today this is a TOTALLY different bike. Thanks guys for all useful info you put on this site for us noobs.
Wheelie
Old Man
posted August 25, 2009 05:15 PM
LOL shazzam Gomer!
wee
rich s
posted August 25, 2009 05:22 PM
You most be warming up to me, that is the nicest thing you ever said to me You love me don't you.
Wheelie
Old Man
posted August 25, 2009 06:01 PM        Edited By: Wheelie on 26 Aug 2009 02:02
it shows huh? hehehe
wee
Newf14
2007 ZX1400
posted August 25, 2009 06:22 PM
I have the TRE-008 in my bike now because when trying to remove my flies I had zero success. I am going to try again your post made me wanna get them pesky flies out. Will I nottice a difference over the TRE-008?
Newf14
INTIMIDA2OR
RED rider!
posted August 25, 2009 07:35 PM
The flies were the 1st mod I did when I got my bike back in august of 06. I've had a permenant grin ever since!
I actually have a flies collection from all the 14's that ever came into my shop. I thought it was funny how every 14 that came in had flies but left without lol!
'06 Passion Red ZX-14
*Lee*
MJ
posted August 26, 2009 01:43 AM
Newf14
The tre gives you about half the effect of pulling the flies on an 06-07, so be prepared for twice what you feel now with the tre.Its well worth it to heat the screws up very well with a soldering iron and pull those flies
Superman T
posted August 26, 2009 03:34 AM
Newf14- If you try and get a Klien screw driver(#2- 9inch, I believe), those screws will come out with a small effort. I would recommend riding the bike for about 20-30 minutes, put it on jack stands, remove some of the fairing(see instructions), lift gas tank cover, and proceed to the secondary throttle bodies. The total job took me about 45-60 minutes. I wanted to make sure I retained my steps and where the different size screws were located on the fairings etc...
BobC
posted August 26, 2009 05:32 AM        Edited By: BobC on 26 Aug 2009 13:32
SupermanT is absolutely right. Using the correct tool is crucial for a job like this.
I bought a new Phillips PH #2 x 250mm (DIN 5262). It worked just fine on a cold engine and all the screws came out without drama. You have to use some downward pressure to make sure it stays properly engaged in the screw head and turn it with care for the first quarter turn.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
Sticks_n_Stones
posted August 26, 2009 05:43 AM
I had my son hold the plates from moving when I removed mine: made it alot easier! Until the last one at least: nothing for him to grab! Definitely use a BRAND NEW screw driver for this job: its critical and prbably the best $10-$15 you'll ever spend (most expensive #2 screwdriver I could find at the Home Depot, they dont carry klein).
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
rich s
posted August 26, 2009 06:06 AM
I agree totally but if you do strip one, that long nose bent pliers will get them out extremely easy no matter how hard they are stuck.
zxbob
posted August 26, 2009 08:49 AM
. . . . . . . "and heat"
Bob
FasterThanStink
posted August 26, 2009 12:13 PM
Take an old screwdriver and heat it up cherry red. Press it on to the screw for 10 - 15 seconds. Then go to the good screwdriver and press down firmly and give it a quick turn. They will loosen with a snap and come out easily every time. Kawi uses threadlocker on them so the heat makes that a non issue.
That's what gets you.
ViEtNAM
posted March 04, 2011 02:02 PM
by pulling them do i risk motor damage
FastestBusaAround
I eat Fish...
posted March 05, 2011 12:26 PM
Not at all - but you should remap to get your AFR in line...can't be running too lean.
FYYFF!!!
swiftnet
posted March 05, 2011 01:48 PM
My screws came out without drama. I saved all the parts, no idea why.
Keeping the rubber side down since 1984
0.48461318016052 seconds processing time
