BIKELAND > FORUMS > ZX-14.com > Thread: Rear sprocket nuts NEW TOPIC NEW POLL POST REPLY
3000psi and falling
posted August 21, 2009 05:39 AM
Rear sprocket nuts
I rounded one of the nuts on the rear sprocket, the dealer will have to order one, can I just get some stainless ones and some washers?
BobC
posted August 21, 2009 06:07 AM
You should use Flanged Head M10 Nuts x 1.25mm thread pitch.
I would not use ordinary nuts and washers. Use the correct ones and also use a medium strength thread lock.
You probably rounded off the nut because of the thread lock. Best tool to use is a six-sided wrench which won't do that. Loosen them off before you take the wheel off the bike.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
posted August 21, 2009 06:45 AM
That's good info bob! You can bust a knuckly pretty good on those teeth if the socket slips!
masszx14
A mind beside itself!
posted August 21, 2009 04:06 PM
Tons of sprocket nuts on ebay- I bought a set in anodized red for my new wheels from there... something like $20.
universal@mind
0.21865606307983 seconds processing time
