BIKELAND > FORUMS > ZX-14.com > Thread: Scorpio Alarm - SR-i900 NEW TOPIC NEW POLL POST REPLY
07zx14blk
ZX6R, ZX9R,ZX12R,ZX14
posted August 19, 2009 05:08 PM
I just purchased a used Scorpion Alarm unfortunately I did not get the factory conector and the instructions are not only very generic but they (in my opinion) suck!
Does anyone have any pictures of there instal or any advise to give me in reference to placement of components or what wires I should be cuting into (or if I should just bite the bulet and order a harnes from the factory).
Cheers
Wheelie
Old Man
posted August 19, 2009 05:15 PM
go to their site, see if they have a harness.
wee
Wheelie
Old Man
posted August 19, 2009 05:17 PM
http://www.scorpioalarms.com/products/accessories/connectors
wee
FasterThanStink
posted August 19, 2009 08:53 PM
Get the harness. Cheap and easy to install.
That's what gets you.
MJ
posted August 19, 2009 11:36 PM
Cheers
If you want the blinkers to flash and the ignition kill hooked up you'll need to do a lot of cutting. If you don't need those extra's its very easy to hook up, the only wire you need to splice into is the license plate light wire. The power and ground go directly to the battery. If you get the plug in harness the wire the directions say plugs into the taillight will actually plug into the license plate light connection, thats a misprint for the 14. You'll still have to cut a wire for the ignition kill though. I skipped the blinkers and ignition kill because I like things simple..less to go wrong
Wheelie
Old Man
posted August 20, 2009 03:25 AM        Edited By: Wheelie on 20 Aug 2009 11:25
Cheers
so the alarm doesnt "plug into" the rear turn signals and tail light?
wee
makenna
posted August 20, 2009 05:03 AM
Wait a month and I will let you see how mine is hooked up, I used the factory connectors though. I would go and get the factory harness though Big K. Order the harness and I will hook it up for you when I am back.
English is the only language that matters.
07zx14blk
posted August 20, 2009 06:09 AM
Thanks for your help.
The factory connector kit and the AC charger for the remote are now on there way (the guy I purchased it from just forgot to pack it).
Thanks for the thought Maverick (aka.. Makenna)… I have given JP a call so I can take a look at how you installed his. As it stands I am thinking the hole thing should go under the seat… the other option is under the tank (no room and would effect signal strength) and under one of the panels up front (no room with the PC on one side and the HID Ballasts under the other side).
JDC
posted August 20, 2009 08:08 AM
If ur like jme, ur gonna like that 900 bing automatic and all. Put on a keyless ignition, and you can 'about' leave your key in your pocket.
MJ
posted August 20, 2009 04:01 PM
Cheers
wee
Sorry Wee I wasn't clear...with the factory connector kit everything plugs in but the anti-hijack module, you still have to cut a wire for that. And you don't plug into the tail light connector, you plug into the license plate light connector, its a 2 wire connector up by the charcoal cannister near the tank.
makenna
posted August 21, 2009 06:31 AM
Whose JP? Do you mean Goose?
0.21671795845032 seconds processing time
