BIKELAND > FORUMS > ZX-14.com > Thread: 16/45 and spray NEW TOPIC NEW POLL POST REPLY
06redzx14
posted August 18, 2009 11:24 AM
16/45 and spray
anybody run this gear and spray if so how much? I thought it was a right on the edge with my 30, but then again I had a horrible 1.65 60' crossed the traps with the shift light on in 6th gear
posted August 18, 2009 11:35 AM
I never used a 16/45 , I used 16/41 with a 30 shoot and hit the traps at 163 MPH .. I think i'm in 5th if i remember right ...
kaw-rick
posted August 18, 2009 11:52 AM
16\43 works great with spray. 163 mph 1/4 for me.
06redzx14
posted August 18, 2009 11:56 AM
i think i'd have to leave on gas with 16/43 it bogs horrible for me on motor. i'll be tuning my setup this weekend and don't want to put it in the limiter testing. I've got the nitrous on the throttle and don't want to run out of gear.
rick what was your setup with a 40shot
posted August 18, 2009 12:04 PM
Just curious, what do you weigh? 16/43 shouldn't bogg down much!
06redzx14
posted August 18, 2009 12:18 PM
240 in leathers
posted August 18, 2009 12:26 PM        Edited By: Shane661 on 18 Aug 2009 20:26
Maybe try a 44T? I think you could get by with the 43, but you would probably have to get more aggressive with it.
I've tried a few gear combos back when I was heavier, the 16/45 was by far the easiest to ride. But I think it's a lot of gear for the spray, since you want to spray as early as you can for ET.
kawasakijockey
posted August 18, 2009 01:27 PM
It should make it Rob unless your spray pushes through the clutch, and it shouldnt.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted August 18, 2009 02:19 PM        Edited By: CrotchRocket on 18 Aug 2009 22:24
16-44 is the closest you can get with spray top of 6th at redline!!!
16-45 puts you in the limiter.....
Your gonna need heavier clutch springs.....5 of them!!!
Make sure you buy a bunch of extra steels!!!!!.....When you hear the clutch squeel, pull out of ur hand and or wheelie.....Open up your clutch and you'll see that when you CANT take the steels out, those are the ones that are WARPED !!!!!
06redzx14
posted August 18, 2009 02:29 PM
Hope the weather holds up so I can test Saturday. May have to play with the delay and build time on the mini
JR
drag racing
posted August 18, 2009 02:46 PM
what you mean by pull out ur hand or wheelie thats on 44t right
08 zx 14 lowered, straped in the
front, strecth 65, air shifter, pigs
windshiel, carbon fiber frame
sliders, full 2brother exhaust.
  Ignore this member    Click here to visit JR's homepage.
posted August 18, 2009 06:10 PM
I'm wanting a 45t, if you want to sell it email me eklipse636 at hotmail dot com
kaw-rick
posted August 19, 2009 03:24 AM
Correction, i ran 167 mph last night. 100 shot. woohoo, these 14s amaze me. im 220 lbs unsuited also. Im gonna take the bike apart and put it back stock now. gonna get serious about running fast. Need to go 7s around here to compete. but im pretty proud of my stock engine to put up with the abuse ive put it through over the yrs.
06redzx14
posted August 19, 2009 05:02 AM
what was the ET rick?
kaw-rick
posted August 19, 2009 02:54 PM
Only 8.80 , but i spun to the 8th. Bikes making real good power, but i gotta step it up to run with these guys around here. Would of made some more passes, but had to help a buddy get his bike ready. Btw i thought the 08-09 being faster than the 06-07 was all hype, but his bike is def faster. Anyway moral of the story is im thinking 16-43 gearing is just right for spraying. I think 16-45 might be a lil to wheelie happy. With my set-up its hard to find the medium between wheelie and spinning. But i know its me. Gotta work on the clutch hand.
0.26742911338806 seconds processing time
