BLK ICE
posted August 13, 2009 10:40 AM
OIL STARVED!!?
The oil pan nut was knock off due to hitting a rock in the road. I was at high RPM when it happened. By the time I got the bike under control (due to oil on the back tire) I had traveled about a quarter of a mile. I was too shocked to notice if my oil light came on as I turned the ZX14 off as soon as I gathered my wits. There was a little oil still draining out by the time I got the bike out of the road.
I did not drop the bike at any time (thank goodness).
Question: What steps should I take to see if it damaged the motor? In order of inexpensive to expensive please, as money is an issue.
Thanks for any and all responses,
posted August 13, 2009 10:58 AM
If I was you my first step would be to clean my pants out!! Lol and after that, I can't tell ya, just make sure step 1 is completed.
Glad to hear you didn't drop it man!
14nooby
posted August 13, 2009 11:00 AM
You are probably ok. If you are worried pull the pan and look for shavings. The same thing happened to me but I have has no problems.
BLK ICE
posted August 13, 2009 11:08 AM
Thanks for the reply, I took it to a shop and without dropping the pan he said "you need a motor".
JR
drag racing
posted August 13, 2009 11:14 AM
i cracked my oil pan too last month. you need to pull the pan look for shaving, check the oil, ant relocate the oil plug to the back. so get it welded would be the cheapest..
08 zx 14 lowered, straped in the
front, strecth 65, air shifter, pigs
windshiel, carbon fiber frame
sliders, full 2brother exhaust.
bigwil
06 zx 14 turbo stage 3
posted August 13, 2009 11:17 AM
dont ever go back to that shop
bigwil// going fast aint easy so turbo it
JR
drag racing
posted August 13, 2009 11:18 AM
quote: Thanks for the reply, I took it to a shop and without dropping the pan he said "you need a motor".
how does that shop gonna say you need a new motor with out pulling the pan and checking for shaving. looks like he is trying to rip you off big time this kind of thing happens all the time. i would fix the pan start her up see how she sounds then take it from their. i would take it to another shop if hes talking like that with out knowing if the motor is bad good luck .
BLK ICE
posted August 13, 2009 11:29 AM
I will not go back, from what he said, I don't want to go to any shop. I am going to try to fix this myself. I'm thankfull for the members on this site and I just need to know the right steps to take.
posted August 13, 2009 11:45 AM
your likely alright,
get the pan fixed , and start it up. you will need to circulate oil to flush any metal out if it ran dry, drop the oil and then you will see bearing material if you did damage.
BLK ICE
posted August 13, 2009 11:47 AM
quote: If I was you my first step would be to clean my pants out!! Lol and after that, I can't tell ya, just make sure step 1 is completed.
My pants checked out OK, but I burnt a hole through the bottom of my boot ; if I would have had sneakers on It would have been nasty!
JR
drag racing
posted August 13, 2009 11:49 AM
quote: I will not go back, from what he said, I don't want to go to any shop. I am going to try to fix this myself. I'm thankfull for the members on this site and I just need to know the right steps to take.
that sounds like a good idea. give it a shot what you got to lose. .
1 i would jack the bike up from the back or both if you want
2 / you pull the side air vents
3/the middle fins lol what eva they call
4/under the front fairing theirs 4 little clips you gotta push in to remove
5/ you un screw the bottom fairing
6/the upper fairing
7/ you gonna have to un screw the radiater top and bottom so you could push it to the side a little
8/ un bolt the hearders pull to side
9/ un screw the oil pan and down she goes lol i would replace the gasket to be safe.
BLK ICE
posted August 13, 2009 12:04 PM
What do you guys think of the Clems pans?
14nooby
posted August 13, 2009 12:41 PM
I just installed a Clems pan. I loved the quality of thier work and no guess work on cutting the oil pickup either. $125 it's a great deal.
JR
drag racing
posted August 13, 2009 07:20 PM
quote: I just installed a Clems pan. I loved the quality of thier work and no guess work on cutting the oil pickup either. $125 it's a great deal.
how long did it take to get the clems pan?
BLK ICE
posted August 13, 2009 09:42 PM
Does the oil level sight glass still read correctly with a Clems pan installed?
14nooby
posted August 14, 2009 03:15 AM
I ordered my pan on a Monday and got it on a Wednesday. The ship Priority Mail which uses Fed Ex air as thier carrier. Most of the US is 3 day shipping. The oil sight glass still reads the same. You will lose that extra .4 ounces required during an oil change. I just use 4 quarts no problems.
Learning2race
posted August 14, 2009 05:17 AM
I ripped the drain plug completely out on a spreed bump. I had a little while before I could stop - tire slipping and traffic trying to run up my backside. Got a used pan from Lyle (Dubious) new gasket, fresh oil and went straight to the track. Have made lots of passes since.
While visually it loks like you dump all your oil in a hurry, it takes some time before the inner parts actually run dry. I won't make any guarentees, but I can't see where you incurred any internal damage unless you tried to drive it home after.
dcjens
Wet side of Washington
posted August 14, 2009 05:52 AM
I've read about this a few times...seems like a good mod to switch to a Clems pan before a guy has laundry issues. is this on lowered bikes?
Black 06
NINJA12
posted August 14, 2009 12:13 PM
you sound like a smart man.
Yes you should get a clem or other cut pan before you lower the bike.
I glad with all these oil downs that nobody has been seriously hurt.
Sticks_n_Stones
posted August 14, 2009 12:23 PM
+1, run it with good oil first! Even if you do have some shavings, I personally say f* it and ride it until it gives a death rattle! Slick 50 FTW
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
BLK ICE
posted August 25, 2009 01:10 AM
Pan was clean(no shavings). Clams pan installed. No problems with the motor.
NINJA12
posted August 25, 2009 06:04 PM
great news!
