BIKELAND > FORUMS > ZX-14.com > Thread: Rear Shock question NEW TOPIC NEW POLL POST REPLY
14nooby
posted August 12, 2009 02:45 PM
Rear Shock question
I want to know if anyone has adjusted the rear spring to add more tension. I weigh 145lbs and even with the tiger tail my tire rubs the undertail. I know its fine rubbing a little bit but I want to know how much to crank the spring down? I can 60ft 1.40's but think with the right spring adjustment and no tire rub I will get 1.30's. The stock setup is good for my weight and I am not going to get and aftermarket setup...........Suggestions?
ninjaboy311
posted August 12, 2009 04:33 PM
If you are only 145 lbs and still rubbing the tiger tail, you must have the dog bones way too low. Pick them up a notch and try that. I'm assuming you have aftermarket dog bones are your bike is stretched?
the14thninja
Show and Go
posted August 12, 2009 05:12 PM
if that doesn't work, i tried the 08 busa spring on my 14, and man its alot stiffer and doesn't scrub and i weigh 235.
I live to ride and ride to live
Big_T112
posted August 12, 2009 05:25 PM
You could get a strait link. Or run the spring tension nut all the way down.
JR
drag racing
posted August 12, 2009 07:18 PM
thats crazy im 210 got my bike in the lowest setting with stock shock and dont rub that i know of lol
08 zx 14 lowered, straped in the
front, strecth 65, air shifter, pigs
windshiel, carbon fiber frame
sliders, full 2brother exhaust.
  Ignore this member    Click here to visit JR's homepage.
Bently
2012 14r In Blue and no Mods!
posted August 12, 2009 07:21 PM
Your not leaving hard then cause at 210 I rub my tiger untail with my spring cranked down
JR
drag racing
posted August 12, 2009 07:59 PM
ur right im not leaving to hard or not pinning the gas i was woundering why it wasnt rubbing.
JR
drag racing
posted August 12, 2009 08:02 PM
do i need to remove the shock to adjust my spring down it preety tight in their
ninjaboy311
posted August 13, 2009 12:12 AM
No, get a spanner wrench. When I had my stock shock, I used a piece 1/4" stainless pipe and a hammer, but I don't suggest that.....
0.23856782913208 seconds processing time
