BIKELAND > FORUMS > ZX-14.com > Thread: chain and sprocket replacment? NEW TOPIC NEW POLL POST REPLY
ShadyD
posted August 05, 2009 08:00 AM
Do you really have to remove the swing arm to replace the drive chain? If so special tool : swingarm Pivot Nut wrench: 57001-1597?
kawasakijockey
posted August 05, 2009 08:14 AM
No. Just cut it off. If you are not replacing the front sprocket use one end of the old chain before pulling it out to pull the new chain back through.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
ShadyD
posted August 05, 2009 08:23 AM
Thanks, I'm going to replace the front sprocket. Do I need to seperate the new chain at the master link?
kawasakijockey
posted August 05, 2009 08:48 AM
Aftermarket chains have a masterlink. If it already together we can assume it is a clip type, right? Yes, seperate it there.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
ShadyD
posted August 05, 2009 05:41 PM
Thanks Kawasakijockey, Fed Ex dropped off my chain and sprockets today. Yep chain has a master link. Thats a lot easier than removing the swing arm. I'm looking for a chain press now.
posted August 06, 2009 04:47 AM
if you have never pressed one together, you'd be better off letting someone that knows how to do it, do it. i dont have a chain press, and im sure i could do it, but whoever brings their press over just does it. you dont want that link comming off, could be bad news.
LAB3
posted August 07, 2009 07:08 AM
See other gearing thread Dubious has a link to purchase a Pro Chain Breaker/ master link install kit. A must for Sport Bikes the cheep one's are junk. Just follow directions that
come with it. really easy after first time.
ShadyD
posted August 11, 2009 05:20 PM
Received The RK Chain Tool, Breaker, Press fit and rivet tool. Thanks for the advice. I'm going to be careful and take my time.
LAB3
posted August 11, 2009 05:26 PM
If you have a Dremel Rotary Tool Kit and use the grinder wheel to remove the rivet
head on the stock chain link Then follow instructions with RK kit. .
ShadyD
posted August 11, 2009 05:57 PM        Edited By: ShadyD on 12 Aug 2009 01:58
Yep, Have a Dremel. Will grind that rivet right off. Thanks!
14nooby
posted August 12, 2009 03:23 PM
I used a pair of needle nose vice grips to press on the new chain link. Works fine
LAB3
posted August 12, 2009 03:53 PM
Done that too and used a dial caliper to measure the distance between the inside of the
front and back link plates. If you used a hand press to mushroom the the pins
like rivets you can press them too tight. The RK kit is designed so this does not happen.
Or did you use a clip type master link.
makenna
posted August 13, 2009 04:31 AM
I have to do mine as well and I figure I will go with a 17/43 for the gearing.
English is the only language that matters.
0.27282094955444 seconds processing time
