BIKELAND > FORUMS > ZX-14.com > Thread: punched in drain plug!!!!! NEW TOPIC NEW POLL POST REPLY
GripnRIp
posted August 08, 2009 11:24 AM
loading my bike on trialer and drove it up the ramp, smack, ripped the drain plug back.
i still have plug, there's a little bit of metal missing. my question is, can i just have it welded back into place?
i already have oil pan off bike.
has anyone else had to deal with this?
what's the best fix?
should i just get a new pan?
please help!!! i still want to ride this year!!!!!!!
Big_T112
posted August 08, 2009 11:29 AM
take it to a fab shop and have them move the drain to the side.
GripnRIp
posted August 08, 2009 11:31 AM
so i don't need a new pan then? they will be able to patch up hole left by old plug and remount it on the side?
gonna take it in monday to a good welder i know and see what he says.
kawasakijockey
posted August 08, 2009 11:42 AM
Give me your email and I will send a pic of what I did to mine.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
Bently
2012 14r In Blue and no Mods!
posted August 08, 2009 11:44 AM
Or just get ahold of clem's and send them your pan and for 125.00 they will send you a shortend pan with the plug moved to the back, works great.
Big_T112
posted August 08, 2009 01:16 PM
a local machine shop charged me $40 dollars. yes they will weld up the bottom hole and move it to the back.
Bently
posted August 08, 2009 04:04 PM
For 40 dollars did they shorten it as well, because in IMO if your lowerd even moving the plug to the back is not enough.
Big_T112
posted August 08, 2009 05:12 PM
no they did not shorten it. The clems pan is best but I was just saying the stock pan could be fixed
JR
drag racing
posted August 08, 2009 06:09 PM
i had the same problem. didnt want to wait for a clems pan. so got the bottom hole patch up and welded then i toke the same drain plug the whole thing and got it relocated to the back of the oil pan. worked out good intill next year. good luck.
08 zx 14 lowered, straped in the
front, strecth 65, air shifter, pigs
windshiel, carbon fiber frame
sliders, full 2brother exhaust.
  Ignore this member    Click here to visit JR's homepage.
GripnRIp
posted August 15, 2009 06:18 AM
i'm putting my pan back on this monday, i punched the drain plug up into the pan when loading it on a trailer. got it welded back in, pan looks great. i have a new gasket.
to help the welding i took the plate off that's held on with red screws, in the pan.
is it really important to use exact ft/lbs of pressure on plate screws, and the oil pan screws?
i'm a little nervous about tighting pattern and i don't have a torque wrench. should i get one for this? or can i just tighten them with roughly the same pressure?
i'm really unsure how important that is.
kawasakijockey
posted August 15, 2009 06:56 AM        Edited By: kawasakijockey on 15 Aug 2009 15:06
The torque on those screws is 87in lbs which is a little over 7ft lbs. Tighten them by hand with a 1/4" drive set. The pattern I did on mine last night was as if you are looking at a clock; 12-6, 9-3, 10-4, 2-8, 11-5, 1-7. This is not exact because you have more bolts on the pan but you get the idea. It works best for me to do it in 3 steps gradually tightening more each step.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted August 15, 2009 08:14 AM
Get yourself an extra oil pan...
GripnRIp
posted August 15, 2009 08:31 AM
ok, i guess i'll buy a wrench, i'll hardly ever use it though....
GripnRIp
posted August 15, 2009 08:32 AM
why get an extra pan??
GripnRIp
posted August 15, 2009 08:39 AM
good info, thanks.
what about the red bolts inside pan, holding down the plate? my seem to have the red lock tight on the threads. should i use the red lock-tight and torque them also?
kawasakijockey
posted August 15, 2009 09:19 AM
I didnt use the torque wrench but I did put locktite on them.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
dcjens
Wet side of Washington
posted August 15, 2009 11:07 AM
Is it just me or is a few people tearing out their plug lately?? +1 KHI ! looks like it time to heed the call and get it relocated.
Black 06
MJ
posted August 15, 2009 02:48 PM        Edited By: MJ on 15 Aug 2009 22:49
I've nicked up my stocker as well, and I was stock length and height with stock suspension settings. I would relocate the stock drain and maybe even shorten the pan a little just to be safe
BLK ICE
posted August 15, 2009 03:30 PM
+1 I just order a Clems pan today should be here by Wednesday. I paid full price $265 and will get a refund $140 for my core (my busted pan) as soon as they receive it. It was the best deal I could find.
GripnRIp
posted August 15, 2009 05:22 PM
well, $60 bucks and two days and i'm back on the road again
posted August 16, 2009 10:35 AM
But did you fix the problem by relocating the plug or just weld up the crack?
Bently
posted August 16, 2009 05:36 PM
Sounds like he just had the plug welded back in same location to me.
07zx14blk
ZX6R, ZX9R,ZX12R,ZX14
posted August 17, 2009 10:08 AM
Not to thread jack… but on my stock height bike when doing a little off roading with my 14 (not by choice I was lost and following my GPS in the Deals Gap area this spring – big mistake), I had a rock tip up under the oil pan and sheer of the plastic deflector and take a chunk out of the oil pan bolt.
Not that this is a regular occurrence but I would suggest this mod to anyone regardless if your bike is lowered or not… stupid design on Kawasaki’s part if you ask me!
0.2678689956665 seconds processing time
