icarus
posted August 04, 2009 08:18 PM
If you are referring to the light in the tach itself it is part of the instrument cluster.
If you want to install an external shift light you will need to tap into a coil wire.
I'm not sure what wire you would need but I think Shane covered it in his build thread.
8.820 @ 161.05
