BIKELAND > FORUMS > ZX-14.com > Thread: Bike will not stay running. NEW TOPIC NEW POLL POST REPLY
dwzx14
posted July 25, 2009 11:21 AM
Yesterday I washed my bike then was going to go for a ride and it will not idle. If I give it some gas it will run but it is rough,like it is not firing on all 4. Water must went somewhere it shouldn't have. I checked the plugs where the Power Comander connects and they are dry. The only thing I found without going through 300 forum pages was about remapping.
I took some plastics off to see if I could get to the spark plugs to check them, haha. I think I need a manual. But I have been wanting to remove the flies for 2 years so I did it and I am going to remap anyway now. I just have to find the cable.
Any other ideas?
JDC
posted July 25, 2009 11:24 AM
got a shop vac use the exhaust to get into the hard to reach places
posted July 25, 2009 11:32 AM
Never thought ab a shop vac...
I washed the motor on my eclipse one time and done the same thing... Got water where spark plugs go. Its gonna be a pain in the rear to get to them on the 14, maybe a air comp and rig up a hose that you can bend to go down in the valve cover holes... Farmers use them to blow out the radiator of cotton pickers.
dwzx14
posted July 25, 2009 11:53 AM
I'll try some air.
dwzx14
posted July 25, 2009 12:36 PM
NOW I CAN RELAX.! I turned the idle up so it would run then with the motor running I remapped and it cleared up. I think the heat helped dry the water and I needed the NOSEC map anyway. Plus I am glad I removed the tank. The plastic just below of the tank/fuel pump was holding water. The pump was sumerged in water and was starting to rust. It was full of road grime and bugs clogging the drain, or what I think was a drain. I ran a drill bit down through it.
All is well.
THX
posted July 25, 2009 02:14 PM
Good deal!!
posted July 25, 2009 02:16 PM
Make sure you check your Power Commander ground as well. That can cause an intermittent issue.
FastestBusaAround
I eat Fish...
posted July 25, 2009 09:52 PM
Also, make sure that you set the TPS in software before you load the map - that can also cause issues if the settings aren't zero'd at idle and aren't 100% at WOT.
FYYFF!!!
0.21424388885498 seconds processing time
