BIKELAND > FORUMS > ZX-14.com > Thread: chain noise ??s NEW TOPIC NEW POLL POST REPLY
unclepaul
new
posted July 24, 2009 09:45 PM
chain noise ??s
i was wondering if hearing a lot of chain noise is normal
i have lubed it and tried tighting it up a lil but i still seem to have a lot of noise
also if i hit a hard bump or speed bump i hear a smacking sound like chain hitting somwhere but its tight not loose at all is this all normal on the 14
BobC
posted July 24, 2009 11:32 PM
If it's lubricated and correctly adjusted and the wheel alignment is ok and it's still making too much noise then it's probably worn chain and sprockets.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
bigtallguy
posted July 25, 2009 12:14 AM
Mine started doing the same thing in the last 500 miles or so. Just ordered a new chain and sprockets yesterday. This one (stock) lasted a little over 17k miles so I'm happy with that.
posted July 25, 2009 04:17 AM
If you decide to replace the chain, make sure you replace both sprockets! And now is a good time to re gear if you would like a little more pep!
LAB3
posted July 25, 2009 04:22 AM
Did you "Clean" really good with WD-40 before you lubed it?? How many miles on the chain?
posted July 25, 2009 04:56 AM
sounds like worn sprokets and chain, or kinked stiff old chain...
A friend of mine once asked me what I thought of the noise coming from the countershaft cover on his bike... every time he would gas it hard it would make a terrible clicking noise...
LOL .... his frt sproket had no teeth left on it, they were worn right off!
unclepaul
new
posted July 25, 2009 07:14 PM
bike is new and has less than 900 miles on it no i did not clean with wd40 but i did wipe it down real good chain is very noisy
posted July 25, 2009 07:20 PM
If it only has 900 miles maybe its a normal sound your not use to, I dunno. Try cleaning it. I don't spray wd40 directly on it, I soak a rag in it and wipe the chain off good (so it dosent sling everywhere) then I spray a little maxxium chain wax on it. Too much will make dirt stick
is the chain adjusted properly, not too tight, not too loose?
posted July 25, 2009 08:11 PM
If the rear wheel is out of alignment, or iof you run an aftermarket frot sproket without thedamper it will be noisy
posted July 25, 2009 08:16 PM
I'd let the warranty man figure it out while I drank a diet coke in the showroom
Douglas Home
posted July 26, 2009 12:39 AM
I'd give the warantee man a free coke if he promised to never touch my bike !!!!!!
previous experience with them was all BAD!!!!!
Doug Mackay Australia
unclepaul
new
posted July 26, 2009 10:38 AM
will be ordering a new chain this week on line i would rather fix the problem myself than deal with the asshole dealer we have in this area thnx anyways guys for helping
posted July 26, 2009 02:08 PM
Your going to replace the chain without replacing the sprockets??? The ekZZZ chain is a really good one. A lot of guys here run it
14nooby
posted July 26, 2009 03:47 PM
Dude! the noise has to be normal if you have less than 900 miles on the chain. I would not worry about it if its the stock chain. It is probably just a noise that you are not used too.
posted July 26, 2009 04:16 PM
I seriously doubt that chain is bad, even if you have never lubed it. IF the chain is wore out, your not going to accomplish much by replacing just the chain without the sprockets. Guys put 15k-up on chains...That's my $.02
unclepaul
new
posted July 26, 2009 06:30 PM
ok zx dude i will give it 500 more miles to see what happens thnx
extrapilot
2008 ZX14
posted July 27, 2009 05:32 AM        Edited By: extrapilot on 27 Jul 2009 13:34
Check the side plates of the inside of the chain. If your have shinny plates, the chain is not running in the middle of the sprocket, causing the noise.
I experience this with my ZRX1200R once.
'pilot
Bluebyyou
Gettin My Curve On
posted July 27, 2009 06:13 AM
Either somethings misaligned or not tensioned properly. At over 20K miles my original stock chain and sprockets still look great and do not nor never have, done that.
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
ShadyD
posted July 29, 2009 06:29 PM
Make sure the alignment is also even after tighting the axle bolt. I have 26,000 miles on my stock chain. I do get a clicking or popping sound when the chain has not been lubed in some time. I used to clean the chain w/ wd40 and lube it with 30 weight oil. I didn't get good results w/ this system. The chain links rusted and stuck together in a couple of spots.
Would a bad chain cause vibration?
posted July 29, 2009 06:39 PM
That's a new one to me. Never heard of putting motor oil on a chain. I bet that made a good mess when you hit ab 60mph. That's what they make chain lubricants for. I understand some people don't like them, but some people like busas too.. What's wrong with these people?
unclepaul
new
posted August 03, 2009 08:41 PM
i was wondering if its because all of you guys have loud pipes and im running stock bike and can hear it better
extrapilot
2008 ZX14
posted August 04, 2009 02:37 AM
I honestly don't think I hear excessive chain noise and I DO have stock cans.
I’ve been riding chain bikes so long that I probable just blank it out of my mind now.
Are you sure that the chain is adjusted properly?
Mine wasn’t right from the dealer, it was way to loose.
The clunking noise when running over a speed bump is the chain hitting the lower part of the swingarm. All the chains on our bikes will hit the lower part of the swingarm, and that’s why they put that chain rail guide thingy on there.
Did you come off a bike that had a drive shaft and now your have a bike that has a chain?
Chain noise is normal to a certain level.
'pilot
NYC ZX-14
Manager Star Toyota Bayside,NY
posted August 04, 2009 05:59 AM
Another possible cause of the slapping noise you hear on bumps MAY be the sidestand (kickstand). Mine sometimes makes a noise over a hard or large bump.
Currently?
2007 Kawasaki ZX-14, 1999 Kawasaki VN 750, 1976 Suzuki RE-5 Rotary
http://www.goldiesplating.com
  Ignore this member    Click here to visit NYC ZX-14's homepage.
HiMile14
posted August 04, 2009 12:02 PM
I think your chain is fine. I suspect at 900 miles your chain is converting from grease to lube and slapping seems normal. If your still concerned mineral Spirit the chain, then wipe the chain down. I would ride 50-100 miles before I'd lube it for the first time. Still sounds normal to me.
Rob
2002 VFR 119,647 miles
2007 VFR 41,619 miles
2007 VFR 6,938 miles
0.21863079071045 seconds processing time
