BIKELAND > FORUMS > ZX-14.com > Thread: suspention help please NEW TOPIC NEW POLL POST REPLY
JR
drag racing
posted July 24, 2009 10:24 AM
okay i been searching the site 4 suspention adjustments but cant get it right. im at 65 and a half wheel base . the top screw which is the compression screw right should be turn all the way in and back off a 1/2 turn right? then the rebound screw which is at the bottom of the shock should be the same all in then back off 1/4 turn. at my wheel base does that sound right to you guys or im i doing something wrong. thanks guys in advance
08 zx 14 lowered, straped in the
front, strecth 65, air shifter, pigs
windshiel, carbon fiber frame
sliders, full 2brother exhaust.
  Ignore this member    Click here to visit JR's homepage.
posted July 24, 2009 10:45 AM
How much u weight?
kawasakijockey
How big a boy are you?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted July 24, 2009 10:55 AM
no matter what the shock is going to be mushy - if you don't beleive me take it to your suspension pro or ship it off
aftermarket the way to go. sticks n stones bought a penski
Your headed in the right direction regardless with the stock suspension being on the soft side. The only other thing is if your a big guy you might need to tighten the spring up.
JR
drag racing
posted July 24, 2009 11:01 AM
im sorry i for got the most important thing im at 195 - 210 so im on yhe right trach then it just it so soft still
kawasakijockey
posted July 24, 2009 11:07 AM
Yeah tighten the spring all the way too.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
JR
drag racing
posted July 24, 2009 12:58 PM
tighten the spring how do i do it? what do i need ? is it easy? i go up with it or down sorry im a little lost with the suspension lol thank for the great info i wish i wouldove stiffen the bike up before i cracked my pan.
posted July 24, 2009 01:14 PM
For me it was a fairly easy task. I took the spring out (2 bolts). Support the bike as if you were putting lowering links on it. ( Rear stand and a jack under the bike was the way I done it) and take the whole shock out. There's 2 nuts on the shock, tighten them with a flathead screwdriver and a hammer. (They make a tool for this but I don't have one)
0.23194599151611 seconds processing time
