BIKELAND > FORUMS > ZX-14.com > Thread: 1/4 mile crash NEW TOPIC NEW POLL POST REPLY
14nooby
posted July 10, 2009 07:28 PM
1/4 mile crash
Went to West Palm Beach dragstrip tonight and what a horrible night for me. I did the minor oil pan mod with the low profile bolt and cut off the guard a few months ago. Well I launched like a normally do and wheelie (a pretty high one) well when I came down I smacked my oil pan and busted it. I could not keep it under control and tried like hell doing so but ended up ruining the left side. Guys, I weigh 145 lbs and if I smack the pan it can happen to any of you. Please take this serious and get the Adams pan or the Clems pan. I finally ended up laying the bike down at about 400ft mark and damn I am sore as hell. It sucks having a brand new 09 and doing something stupid to F it up.
Bently
2012 14r In Blue and no Mods!
posted July 10, 2009 07:34 PM
That's why I went with the clem's pan!
posted July 10, 2009 07:57 PM
Sorry to hear this ..The bike we can fix..... Hope your ok , did you get checked out ?? I still have a few odds and ends left over fron an 06 i parted out ..Make a list of needed parts and we will see if we can fill it ..
Smokin ..
Rideharder
posted July 10, 2009 07:59 PM
I actually was going to go to the track tonight and try a couple of nitrous shots..
Do you have any photographs of the bike...
I have a bunch of parts and I live in West Palm Beach also...
I'm thinking about parting one motorcycle out...
Do you ride on Sundays on beeline?
  Ignore this member    Click here to visit Rideharder's homepage.
14nooby
posted July 10, 2009 08:08 PM
Yes,
I am ok no broken bones just bruises and a sore ego! Thanks for asking though. Here are some of the items that I need. LFT tail fairing, LFT upper and lower fairing, front fairing and a new clutch lever. I just ordered a clems pan for $265 so I am good there. One question is I have two gallons of MR9 in the tank which I will drain tomorrow but what about the fuel injectors and the fuel system how should I clean it out. I obviously cant crank it and run pump gas through it. Will compressed air work on the fuel hose???
Chad
14nooby
posted July 10, 2009 08:14 PM
I will post some pictures in the morning. I actually live in Melbourne and had never been to WPB to run before tonight. I did meet some guy on a 08 SE with a 50 shot. He was from Cape Coral and I think his name was John.
posted July 10, 2009 08:19 PM        Edited By: smokinZX14 on 11 Jul 2009 04:21
Yes,
Chad
Better pull the tank and dump the mr9 , flush the tank with some pump gas ... If it were me i'd pull the injectors ( TBs ) off the bike and flush them with some pump gas .. The throttle bodys are pretty easy to remove ..
As far as parts i will look Sat and see what i have .. Glad you are ok ..
Rideharder
posted July 10, 2009 08:35 PM        Edited By: Rideharder on 11 Jul 2009 04:38
Good to hear your okay...
Was you wearing full leather? I know that they been kind of lenient on the riding gear at that track.
Did you break the clutch lever or did you bend it?
I should be able to snag a clutch lever for you..
Only belly pan I have is left side carbon fiber..
Rideharder
posted July 10, 2009 08:43 PM
I missed your last post on your location looks like you're closer to smokinZX14.
I'm going to call it a night but if you need a clutch lever just e-mail me your address to speedaholic.net@gmail.com..
Look on the bright side you is able to walk away to ride another day!
Take care..
dcjens
Wet side of Washington
posted July 10, 2009 08:52 PM
that has to do nothing for the superior male ego...sigh. Glad your ok I seem to keep er at a loft here and there after my mishap. I am curious... is a person "on the own" insurance-wise at a race track? mum's the word I imagine. I have a front fender sitting in a box btw, in perfect shape (10 mod)
Black 06
posted July 11, 2009 06:49 AM        Edited By: Shane661 on 11 Jul 2009 15:49
Sorry to hear this happened! What is your setup on the front suspension? Are your forks slid up at all? Any preload on the forks?
reynoldss
posted July 11, 2009 08:21 AM
Man this is what a forums all about!!
Everybodys tyring to go green, I did years ago.
14nooby
posted July 11, 2009 08:50 AM
Shane,
I have the forks slid up 1" and then I strap it the rest of the way. I made no adjustments to the preload on the stock forks.
posted July 11, 2009 08:57 AM
Shane,
Stock profile front tire?
The reason I ask, is just to get an idea of what is really pushing it. My forks are slid up .5" with a .25" shorter tire. I back the preload off, then strap it, and then spin the preload down to tighten it up as much as possible.
I believe that when Bently broke his, he was slid up 3/4" with a stock drain bolt setup. Sorry if I'm mistaken, but that is what I recall.
Definitely something to watch out for. I think the short plug mod is worlds better than stock, especially for the street. But once you slide the forks up, you really change the equation.
14nooby
posted July 11, 2009 09:01 AM
Stock front tire and I agree with you that short plug is great mod and thought I would be fine due to my weight but........I was not ok. It did not just crack the pan but it moved the plug up quite bit and left a rather large hole.
TooHype
Go Hard or Go Home !!
posted July 11, 2009 09:04 AM        Edited By: TooHype on 11 Jul 2009 17:49
Glad your OK Chad! Frame sliders can help out in a lot of cases. I have heard in a few rear instances when they have done more harm than good but for the most part I have seen a lot of plastic saved and untouched from crashes...............Just my
LAB3
posted July 11, 2009 09:14 AM
Yes,
Chad
Chad
Glad you are OK. Hope the engine is not hurt from oil pan breaking. I have a clutch level
if you need it.
Louis
Fifty Thousand
Lovin My Family.
posted July 11, 2009 01:32 PM
Usually If you tell the insurance it happened at a track, your on ur own..... Now if this accident happened anywhere else under normal riding conditions.( wink wink) you would be covered....
Rideharder
posted July 16, 2009 10:36 PM
14nooby check your e-mail..
ninjaboy311
posted July 17, 2009 12:00 AM
Glad you're ok. I hope people that drag race are reading this. If you are going to drag race (or lower your bike period), get the Adams or Clems pan. I see this happen to too many racers.
Once again, glad you were able to walk away. As unfortunate as it was, I hope it opens the eyes of others and prevents future accidents.
NINJA12
posted July 17, 2009 05:45 AM
I agree, when you get lowering links get a modified pan. PERIOD.
You are on borrowed time with this bike lower and a stock pan.
Don't hurt yourself or someone else over $125.
gilberjj
Friend of Fast
posted July 17, 2009 08:10 AM
I have yet to hear of someone crushing their pan having not lowered their forks in the clamps. Have you guys?
Beondwacko
posted July 17, 2009 02:09 PM
Next time you head over to PBIR,,,,, if it's on a wednesday, drop me an email with a phone number so I can meet up with you out there. This is the track I play at when I can. Work schedule has been very demanding and I haven't been out ther for 6+ weeks now.
Sorry about your incident too. If you need a Chiropractor,,,,,, drop me a line. That's what the family business is for me and my wife.
Adam
shankrr
posted July 18, 2009 04:21 AM
Anybody have one of these custom oil pans for sale? Clearance is not really my issue, I need a relocated drain plug pan. Email me at shankrr@yahoo.com
14nooby
posted July 18, 2009 03:14 PM
RideHarder
I sent you an email using the new email that you gave me and it kicked it back to me. Dont worry about the clutch lever though. I just put all the new parts on my bike on Thursday only thing left is the zx14 sticker and the ninja sticker. The new fairings come naked. Yes you did hear correct that I did not have an engine kill. (waste of money) The bike kills when it falls due to the tip sensor. Thanks for your generous offer though.
Beondwacko.......I will let you know if I head that way.
0.25893187522888 seconds processing time
