BIKELAND > FORUMS > ZX-14.com > Thread: bruno nadeau - Motty AFR NEW TOPIC NEW POLL POST REPLY
cycle junkie
posted July 05, 2009 01:19 PM
Do you have an AFR map you were satisfied with on your '06?
Could you email it to me so that I might try it, or at least see where to start on developing my own?
Thanks,
Chris
cts@oecblue.com
http://www.performancephotos.com
"Any society that would give up a little liberty to gain a little security will deserve neither and lose both."
-Benjamin Franklin
  Ignore this member    Click here to visit cycle junkie's homepage.
bruno nadeau
posted July 06, 2009 04:19 AM
i am not home now .i will email to night,
bruno nadeau
cycle junkie
posted July 06, 2009 07:43 AM
Thanks Bruno.
-Benjamin Franklin
JDC
posted July 06, 2009 05:34 PM
cycle,
If your Motty is similar in goal to the Bazzaz, couldn't you set your A/F, say to 13.1:1, then run the bike?
On the Bazzaz, I've set the A/F to three states. 13.7 (cruising RPM 3-6K at 3-9 percent TP), 13.1 and 12.5 (under full boost). with transitions in between.
bruno nadeau
posted July 06, 2009 06:13 PM
i set mine on the motty 4 to8% 3400 to 4400 at 14,7 and have some 14, 13,5 for transition and finally 12,9 at 16 to 100% 4800 1o 11000. thats not mean it is the best map it is a starting point i have to work on it wen it will be instaled on my 09 but it work well that way on my 06.it is easy to see if i go the wrong or the right way with the dataloger and the software that come with the motty.i dont know exactly how the bazzaz work but for the motty you build a afr map and the motty build the injector map as you ride the bike.to keep the last update of the injector map after a ride you have to stop the engine by the kill switch before using the key to power of and the motty keep the update in memory.
bruno nadeau
cycle junkie
posted July 06, 2009 06:29 PM
JDC, bruno,
Thanks that's what I'm looking for.
Tamas did send me a sample map, but it was for his GSXR1000.
-Benjamin Franklin
bruno nadeau
posted July 06, 2009 06:52 PM
Thanks,
Chris
cts@oecblue.com
did you get my e mail .bruno
bruno nadeau
cycle junkie
posted July 07, 2009 11:20 AM
Got it!
Thanks Bruno!
-Benjamin Franklin
0.21711111068726 seconds processing time
