BIKELAND > FORUMS > ZX-14.com > Thread: increase in mpg NEW TOPIC NEW POLL POST REPLY
robzx14
posted July 04, 2009 10:04 AM
increase in mpg
pulled the secondary files out K&n filter pc3 lot more power on bottom and better gas mileage that is great getting 35 miles per gallon
FastestBusaAround
I eat Fish...
posted July 04, 2009 12:47 PM
Ummmm no, I don't think so - more power = more gas consumption. Unless you have several thousand miles from before and after - accurately measured and documented, the better mileage is likely only a psychological thing...seriously. Every mod I've done has resulted in less mileage/tank, which is inline with the way things generally work.
FYYFF!!!
robzx14
posted July 04, 2009 12:54 PM
Was getting 34.5 mpg i rode today got 35.2 that is better mileage in my book lot more power to boot
Tool Man
posted July 04, 2009 01:31 PM
You must be riding slower... FBA is correct more gas in = less MPG
The banks are failing..
The banks are failing...
Invest in Ammo
FastestBusaAround
I eat Fish...
posted July 04, 2009 01:55 PM
He measured it on one day's ride for a few miles - probably from the MPG gauge too...not accurate.
Dude - you gotta run at least 10 tanks before and 10 after - riding in the same place then and check total mileage before and after. You will see you're down after the mod's - either that, or your now riding like a pussy...
FYYFF!!!
dcjens
Wet side of Washington
posted July 04, 2009 02:18 PM
I remind myself that this beast already has better gas mileage than the majority of cages and performance is on the edge of insanity...fair trade...Buy a vespa to apologize to the planet... not a 14. just my $3.86 worth (inflation)
Black 06
bruno nadeau
posted July 04, 2009 03:53 PM        Edited By: bruno nadeau on 5 Jul 2009 00:03
you can get better mileage and better power with a good map.i set my map to get 14,7 at crusing speed(below 12% throttle 70 to 80 MPH and 12.9 for power upper12% throttle on my motty afr tuner) on my 06 i went from about 175 miles to about 205 miles before the gas light come on wen i dont abuse the bike 70 80 MPH and faster to pass car or sometime a little hi speed pass.you dont need to run rich at crusing speed.i test it 5000 miles on my 06 before i trade for a 09.thats about 45 MPG canadian gallon (miles are from GPS=speed and odometer.computer on the bike is not accurate and it is worst with a pc3 or a motty afr tuner.i will instal the motty on my 09 next week and post the numbers.
bruno nadeau
Ozonkiller
posted July 06, 2009 08:35 PM
208.32 MPH at Texas Mile...
Rode from Phoenix to LA this last week @ 85+ and got 42.6 mpg (measured not by the MPG thingy)
Who says you can't make power and get economy?
01smokes
posted July 06, 2009 08:48 PM
my 14 seams to suck fossils out of the ground it gets worse millage than my car but its 1000000000000000000000000000x funner to ride than my car so ill ride the bike when i can
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
zixxer14
Damn that was Quick
posted July 06, 2009 09:26 PM
This thing doesn't get MPG's it gets GPM's(grins per mile) and occasional TPM's(tickets per mile)!
BobC
posted July 07, 2009 02:41 AM
I think pulling the flies can give better gas mileage. It allows you to use a higher gear for normal street riding and still get a good throttle response. Just depends how you ride, I get around 43mpg on the highway.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
DEK
posted July 08, 2009 06:35 PM
seems to me that if you went from an overly rich condition to say a better running leaner condition that fuel milaqe could be better.
gilberjj
Friend of Fast
posted July 08, 2009 07:00 PM
I got better mpg when I pulled the flies and added a pcIII. It was less rich at wot, and it was easier to pull a lower gear.
posted July 08, 2009 07:07 PM
I am thinking most are seeing the mileage change due to both intake and exhaust.
If you don't have to get into it as long, to accellerate the same it might work out.
Definately the stiffled exhaust was not helping, thurning fuel into heat, instead of power.
ShadyD
posted July 09, 2009 04:38 PM
You guys are getting crazy gas mileage. On my 2003 I only get 30MPG on average. 50% highway & 50% back roads.About 35 MPG on the highway.The Bike is stock. What gives?
Port_Angeles_NINJA
posted July 09, 2009 05:00 PM
i never get better than 30 mpg either (2007), usually not even that many
Red/Black 85' GPZ900
Blue 07' ZX14
extrapilot
2008 ZX14
posted July 09, 2009 05:17 PM
I believe I could get better than 38mpg, that I regularly get now. My pipes are always leaving dark deposits on the insides. My buddies 08 Busa gets 43+mpg and his pipes are clean as a whistle. Both bikes are bone stock and broken-in.
'pilot
0.28011989593506 seconds processing time
