BIKELAND > FORUMS > ZX-14.com > Thread: 1000-MILE TRIP, BURNT A QUART OF OIL NEW TOPIC NEW POLL POST REPLY
butta4hc
posted July 03, 2009 12:58 PM
I took a trip from New Jersey to Cleveland this past weekend and when I got back I had to replace a quart of oil. I also heard from my members They see a poof of smoke every once in a while when I get on the throttle. The bike runs strong and doesn't seem to give me a problem otherwise. It looks I will be getting some major work soon. Does this sound like rings? Is there anything else I need to know before/during/afterwards? I won't be doing the work myself. I'm no engine guy. Any TECHNICAL input would be appreciated
Butta
Hot Commodities MC
Paterson, NJ
2006 Black ZX-14 - Recall Frame Swap, Full Muzzy GP Exhaust, PCIII, BMC Race Filter, Flies Out, Braided Front Brake & Cutch Lines, Muzzy's Radiator Fan, Engine Ice Coolant, Frame Sliders, SubFrame Sliders, Puig Dark Smoke Windscreen, Powerbronze Hugger, Cox Radiator Guard, Unswitched Powerlet Outlet under seat, Switched Powerlet Outlet On Right Duct Panel, Intergrated Tail Light, HID lights high and low beam, Blue corner marker lights, Eclipse License Plate Blackout Kit, Black Pazzo Levers, Scorpio Alarm, Lojack Theft Recovery System, Rapid Transit Triple Tree Bag, Cortech Tank, Tail & Saddle Bags and the bragging rights for being "The Fastest 14 In The Country" for a few weeks when the 14 made it's debut here in the states.
  Ignore this member    Click here to visit butta4hc's homepage.
zixxer14
Damn that was Quick
posted July 03, 2009 01:22 PM
That kinda happens when you run WFO! But then don't we all?
butta4hc
posted July 03, 2009 02:27 PM
Of course who would I be kidding to say I don't go over the speed limit. I averaged 100-110 going to Cleveland and when I rode to Mobile, AL...let's just say we made good time, lol. I know bikes are gonna burn oil at some point but I think a quart is a bit excessive.
Butta
Hot Commodities MC
Paterson, NJ
posted July 03, 2009 03:09 PM
at 100 -110 the rpm is ? 6500? Thats a decent sustained rpm....
If you run it at high rpm with the oil level over half on the glass, it will pump it into the airbox.
If you run it at extended high rpm, with it at half on the sightglass, it will starve under hard acceleration, or the top end won't get enough oil at low (1100 rpm idle).
Its catch 22 and would keep the oil at 3/4 sight glass and continue on without much concern
I put 10,000 HARD high speed high RPM miles on mine, borderline abuse some would say... they can endure alot of hard use.
If you want to prove my theory, pull the inspection covers off the airbox and wipe inside with a white rag.... very likely you will see wher the oil is going.
The only thing that would cause accelerate ring wear is dirt ingestion IMO, check the TB boots, I did find 2 that were alarmingly loose.
butta4hc
posted July 03, 2009 11:47 PM
This very good info. I plan to jump on this first thing in the morning hopefully with little to no protest from the five year-old. When I first got the bike I noticed my boots were ridiculously loose. I will check them again as well. I will let the board know my findings.
Butta
Hot Commodities MC
Paterson, NJ
Superman T
posted July 04, 2009 05:13 AM
butta4hc- In addition, you might want to check and see if the engine is leaking oil through the valve cover(some have complained of this)
butta4hc
posted July 04, 2009 06:37 PM
valve cover. I will check.
Butta
Hot Commodities MC
Paterson, NJ
jarhead
posted July 04, 2009 08:33 PM
Its a Kawi, if it isn't leaking a bit of oil its just not happy.
posted July 05, 2009 04:45 AM
I thought it was harley that used/leaked oil??
butta4hc
posted July 05, 2009 08:35 AM
My 11 leaked & passed oil. I kept a quart on standby @ all times. I sold it with 37,000 on it. Probably 20 of those were with a standby quart. I do have a leak up front possibly the valve cover coming from the left side of the bike. After a long trip i have a few drops that have sprayed back onto the fairing that meet with the lower fairing. Never though of it as too big fo a deal as long as it wasn't on my rear tires or rearset. It looks like one way or another I will be dropping the motor. I may wait to the end of what most people call the "riding season" to do it. I will still look into the airbox though when I get a chance. The lil one kept me busy over the weekend.
Butta
Hot Commodities MC
Paterson, NJ
posted July 05, 2009 09:47 AM
I very seriously doubt you need an engine rebuild
INTIMIDA2OR
RED rider!
posted July 05, 2009 05:41 PM
How many miles on your machine?
'06 Passion Red ZX-14
*Lee*
INTIMIDA2OR
RED rider!
posted July 05, 2009 05:58 PM
I know my passion red 14 just turned 50,000 then got stolen out of my garage by some douche bag who bottomed out my bike on something and took out my oil pan and dumped her on both sides. But before that she never burned a drop of oil.
*Lee*
butta4hc
posted July 05, 2009 07:19 PM
I got it with 1200 race miles on it. I got over 13,000 on it now. Mainly highway. Barely cruise around town with it. Had two other bikes for that.
Butta
Hot Commodities MC
Paterson, NJ
NeverKnow
posted July 24, 2009 09:07 PM
What type of oil are you using... Some brands evaporate more than others due to high heat conditions. Amzoil and Mobil 1 are 2 oils with low evaporation numbers. I ride with a buddy with a V rod that burned a 1/2 quart per 300 miles on Harley synthetic; switched to Amzoil and now burns zero between oil changes.
posted July 25, 2009 04:15 AM
You think the harley used oil bc it evaporated? That's a new one to me. Anyone know anymore ab that?
NeverKnow
posted July 25, 2009 05:47 AM
http://micapeak.com/info/oiled.html
"Flash point is the temperature at which an oil gives off vapors that can be ignited with a flame held over the oil. The lower the flash point the greater tendancy for the oil to suffer vaporization loss at high temperatures and to burn off on hot cylinder walls and pistons. The flash point can be an indicator of the quality of the base stock used. The higher the flash point the better. 400 F is the minimum to prevent possible high consumption. Flash point is in degrees F. "
More articles to review.
http://www.bestsynthetic.com/harleyoil.shtml
http://oilspecialist.com/motor-oil-tests/comparative-motor-oil-testing.html
http://motorcycleinfo.calsci.com/Oils1.html
NeverKnow
posted July 25, 2009 11:45 AM
This is a water cooled Harley as you know. The Porsche motor isn't designed to burn oil as the traditional air cooled.
billeason
posted July 25, 2009 01:44 PM
intake manifolds
Also check the clamps on the intake manifolds for tightness . I have seen a lot of the earlier 06-07's with a bad back fire that was caused by this. I think i see in your post that you may be want to get into that motor for some hp up grades. Hee Hee! Have fun.................Bill
bill eason
posted July 25, 2009 08:14 PM
lol @ the "valve cover" leak, mine aggravated the $%#^ing hell out of me that such a thing would happen in this day and age (to a bike other than harley)
0.22071599960327 seconds processing time
