BIKELAND > FORUMS > ZX-14.com > Thread: Dyno testing ....... NEW TOPIC NEW POLL POST REPLY
posted June 28, 2009 03:01 PM
We got the Dyno up and running all but the two cooling fans ...I put my 09 zx14 on the Dyno and made two quick test runs to make sure it was working ..
I didn't air up the tire from last Thursday test & tune. so it was at 12 PSI ...I didn't even lube the chain... I just loaded it on the dyno and made two pulls in SAE mode ..
This was with Brocks track map , flys IN , 87 pump gas .. I was guessing that it would make 174 hp and guess what , I was damn close ....
01smokes
posted June 28, 2009 03:38 PM
what for even have a dyno when your that close hahahah, good numbers are you going to leave it there or try to get a few more ponies out of it?
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
posted June 28, 2009 03:50 PM
The hole point of having the dyno is to find more HP ..I will be testing different maps , fuels , timing and a anything else that may or may not make more HP .. First test will be to pull the flys and add a no flys map .. I also what to test the APE cam chain adjust Vs the factory unit .. Some have noted the bike runs stonger with the APE unit and i want to see if that is true ..
If there is something you guys want tested let me know ..
Smokin ..
14nooby
posted June 28, 2009 04:50 PM
Very curious about the cam chain. Also would be curious to see how much HP 0wt oil vs. 10w40 makes. I know you will post up most of your test results anyways but thanks in advance.
pazx14rider
posted June 28, 2009 05:08 PM
Lee, did you ever get your 06 dyno'd? I would be interested to see what the difference would be between flies out of the 06-07 compared to flies out with the brocks map and on a 08-09 flies out and brocks map.
posted June 28, 2009 06:24 PM
I never did put it on a dyno ...I did have it on one of the dyno drag machines but the numbers were crazy high ...
Lucky for us we have a friend with a 06 red ZX14 that is set up just like my 06 zx14 was ... He even has my old pipe and runs the same map.. I will be doing some dyno testing on his shorty and that will give us some numbers to compair to the 09 zx14 set up the same way ..
Also i'm going to test JesseJames 06 red zx14 with the thin head gasket and Deg cams , it will also a Brocks pipe and Brock map ..
01smokes
posted June 28, 2009 09:28 PM
Smokin ..
what tire are you on? if its the shinko i herd they can kill power is that true?
posted June 28, 2009 09:37 PM
Smokin ..
Yes i run the Shinko Usoft ... Maybe we can test a few different brands of tires and find out if that's true ..
AcadianaZX
Advertiser
posted June 28, 2009 11:31 PM
Smokin, I will send you more oil if you would like to try. I think the 5w20 Racing Dominator will be reliable and net more power. I was glad to hear the 10w30 had more clutch grab for you.
James
SteddyTeddy
posted June 29, 2009 04:42 AM
Looks like my ZRX will be the dyno king so far. LOL
AcadianaZX
Advertiser
posted June 29, 2009 06:04 AM
Is that going to be all motor
SteddyTeddy
posted June 29, 2009 06:10 AM
Yes, all motor. She pulled 179.28hp and 101 ft-lbs SAE on this same dyno before we bought it. I'm doing another head and want to increase the CR a little more. Hoping to break 190hp. Lee will still be faster at the track but at least I can claim a win somewhere. LOL
AcadianaZX
Advertiser
posted June 29, 2009 06:29 AM
That's what i'm talkin about. I'll be trying to catch up to you guy. More seat time for me though.
Superman T
Smokin, was that dyno expensive? What a awesome piece to help you tune!!! I'm approximately 2 hrs away from you but I would like to hook up with ya soon if applicable. I look forward to your posts for education... have a good one
posted June 29, 2009 11:46 AM        Edited By: smokinZX14 on 29 Jun 2009 19:47
Teddy i got the one big fan up and running .. It puts out so much air i'm not sure we need the other fan ..Anyway everything is up and running and all seems to work just fine .. Greg my friend a block away could hear my dyno pulls , he thought someone was making an all out pass on Seminole .. He said it wasn't all that loud or that bad as far as noise .. I had the doors to the shop open ..
posted June 29, 2009 11:49 AM
James
James i would be happy to test 5w20 racing oil Vs the 10w30 .....
posted June 29, 2009 11:52 AM
We got a good deal on the Dyno , about a third of the cost of a brand new one... Drop me an Email at ply500cid@aol.com ....
SteddyTeddy
posted June 29, 2009 12:23 PM
If the 1 fan is enough, just makes it easier to wire up.
JR
drag racing
posted June 29, 2009 02:42 PM
smokin i went to a shop last week to get my bike dyno i got the 2 brother full exhaust system i know its not the best but me and a freind wanted to know how much power it had the bike runs pretty good tho . to make a long story short could you beleave wonce we got the bike up on the dyno after the run these clowns were trying to tell me my bike only got 155 hores i told him somthing has to be wrong with ur dyno . he say the dyno is brand new it looks it dyno jet . the funny part was the 630 pounds of torqe lol but he says the dyno is good. lol
08 zx 14 lowered, straped in the
front, strecth 65, air shifter, pigs
windshiel, carbon fiber frame
sliders, full 2brother exhaust.
  Ignore this member    Click here to visit JR's homepage.
posted June 29, 2009 03:17 PM        Edited By: smokinZX14 on 29 Jun 2009 23:28
Update dyno runs ....
I added Brocks Track map , Flys OUT , 89 pump gas map . I removed the flys and loaded the bike back on the dyno and made two pulls ... Temps ( 89 deg ) and humdity ( 77% ) were the same as yesterdays pulls .. On the chart you will see yesterdays best pull and todays best pull ..
On the next Dyno chart you can see the difference in TQ down low as well as a better AFR 12.0 Vs 13.0 ... The bike revs much faster now , real snappy on the throttle .. So i picked up 4 HP and 4 foot pounds of TQ across the total rev range ...Peak HP 10600 was a 4 HP gain ....
posted June 29, 2009 03:25 PM
Teddy 177.60 HP and 103.74 TQ ...Now i have more TQ than you !!!
posted June 29, 2009 03:31 PM
630 foot pounds of TQ ... lol i want some of that .... Something is wrong with that dyno or the guy running it ...
Ninja ZX-14
posted June 29, 2009 03:36 PM
Smokin ..
The Shinko does kill power. Had the same exact tire on my bike, not knowing that it made a difference, HP wise or else I wouldn't have put it on. My bike was making 196 prior to the shinko.I put the shinko on and I changed the stock air filter to a BMC, dynoed my bike and noticed a 10 hp drop. l asked my tuner about the HP loss. He asked me if I had changed this, this or that, I told him that I changed my tire, He looked at the tire and said, "thats your problem right there." I immediately had the tire removed and gave it to a friend of mines who runs Shinkos. I replaced it with a Michelin, put bike back on dyno and the 10 HP was back. I never thought about a Shinko sense. If you don't want to lose HP, don't run a Shinko!
Ninja 14
posted June 29, 2009 03:41 PM        Edited By: smokinZX14 on 29 Jun 2009 23:42
Smokin ..
What Michelin did you get ? Michelin power one ?
posted June 29, 2009 03:43 PM        Edited By: Shane661 on 29 Jun 2009 23:43
Very close to what mine showed with the shortmeg and street map:
How much difference is there between Dynojet units? This was done on a 200...
0.24527215957642 seconds processing time
