BIKELAND > FORUMS > ZX-14.com > Thread: Going into Neutral NEW TOPIC NEW POLL POST REPLY
dogg24
posted June 28, 2009 07:50 AM
Going into Neutral
I got a question. A couple of times here recently when I've been riding and I go to shift into 2nd gear it has slipped into neutral. Could this be a problem or am I just not shifting hard enough? When it happened it was when I first got on the bike so is it possible that it might not have been warmed up enought or something like that? Thanks.
2012 ZX14R SE, Streetmeg, PCV
FastestBusaAround
I eat Fish...
posted June 28, 2009 08:32 AM        Edited By: FastestBusaAround on 28 Jun 2009 16:32
2 things --
1) Either you're not shifting hard enough
2) Your shifter isn't placed properly - more likely.
Adjust your shifter peg to the correct height and that should fix it!
FYYFF!!!
Big_T112
posted June 28, 2009 09:01 AM
Or worse if you have damaged the engagement dogs on 2nd gear. or a slightly bent shift fork. If it jumps out of gear under heavy load then you have problems. remember if you miss a gear, wait until the engine RPM dies down before putting it back in gear. but that's worse case.
dogg24
posted June 28, 2009 09:22 AM
I figured I wasn't shifting hard enough, but just thought I'd check with everyone. I would think it wouldn't be possible that the engagement dogs on 2nd gear are damaged due to the fact that I only have like 850 miles on it though. The 2 times it popped into neutral though I slowed down and pulled over and then put it back into first so no problem there big T. Thanks for the info though guys.
KLD
posted June 28, 2009 10:28 AM        Edited By: KLD on 28 Jun 2009 18:35
I have accidently kicked it into neut a few times too, unfortunetly i was in traffic and wasn't thinking at the time, so i tried kicking it back into 2nd without matching rpms, I don't think i broke anything, but whats a good way to see if I screwed something up?
posted June 28, 2009 10:38 AM
look for chunks on the next oil change
knydecker
Uber-BigPimpin
posted June 28, 2009 10:41 AM
I agree w/ BD. The transmisions are very deliberate. Its hard to pick a wrong gear or neutral by accident. Check the oil.
This was dictated... but not read!
zx-twitch
the dude abides
posted June 28, 2009 11:24 AM
bleed the clutch. trust me it works
carlsbadbusa
posted July 02, 2009 09:03 AM
if moving your shifter and shifting harder does not fix it and you keep going into neutral you can get a shift star kit from muzzy.
dogg24
posted July 02, 2009 10:30 AM
I'm pretty sure the problem was me not shifting hard enough. Like I said it only happened a couple of times. I was just trying to rule out anything else if there was anything.
FastestBusaAround
I eat Fish...
posted July 02, 2009 11:22 AM
Shit happens - on my (3rd) Connie 14, the day I drove her home from the dealer, it got stuck in 4th 4-5 times and wouldn't budge out of it. It has never happened since in 2000 miles.
FYYFF!!!
AlexTheUkrainian
'08 ZX-14 SE
posted July 02, 2009 10:01 PM
I shift into neutral from 1st when trying to shift to 2nd pretty much every ride and I seem go def. shift hard enough.. It flunks real loud too.. Guess I'll be looking for chunks in next oil change eh?
KLD
posted July 02, 2009 10:37 PM
Just changed my oil and not a single peice of metal :-o
ZX11D
Internet Police
posted July 03, 2009 07:42 PM
Try going into false neutral between 5-th & 6-th. I did, few times, up to 2 k. After that, never happened again. Now at 8.5K on my 2007, everything is just fine now. I can attribute it to break-in......or........just lazy shifting. Either way, do not get alarmed by some shifting glitches. I dos not necessarily mean your tranny has a problem.
'94 ZX-11
'07 ZX-14
0.25449395179749 seconds processing time
