BIKELAND > FORUMS > ZX-14.com > Thread: gained a lot on bottom NEW TOPIC NEW POLL POST REPLY
robzx14
posted June 28, 2009 04:03 AM
pulles real strong on bottom but seems i lost some on top is that because i hav no power commander maybe to lean getting pc
CajunBoyz
posted June 28, 2009 05:48 AM
Most chances are you will be pulling fuel at the top(10k range) being factory ecu has it sooo rich.
NINJA12
posted June 28, 2009 06:04 AM
what did you do to gain on bottom?
14nooby
posted June 28, 2009 07:30 AM
You need to buy a PC. Now you have got way more air at low rpm and your ecm has no idea what to do. It will pull even harder once you get it mapped depending on the year of your bike.
robzx14
posted June 28, 2009 09:12 AM
pulled the flies out as much differance as day and night
posted June 28, 2009 11:46 AM
way to go , now get a power commander and map it, pipe it if you can
NINJA12
posted June 29, 2009 03:20 AM
Pulling the flies will not change top end mapping, because the flies would be 100% open anyway. It does get you more power sooner and eliminates the big 2stroke hit .
You need a PC to fix the bottom end AF ratio because you have more air compared to stock.
bruno nadeau
posted June 29, 2009 03:42 PM
what year is your 14
bruno nadeau
mike1024
posted June 29, 2009 09:57 PM
IF YOU HAVE A LOT OF BOTTOM, TRY THE LAP BAND. GET IN SHAPE FOR SUMMER!
robzx14
posted June 30, 2009 02:07 PM
it is 06 zx14
carlsbadbusa
posted July 02, 2009 08:55 AM
HA!
0.22102785110474 seconds processing time
