BIKELAND > FORUMS > ZX-14.com > Thread: Muzzy fuel pump NEW TOPIC NEW POLL POST REPLY
1badvespa1400cc
power junkie
posted June 22, 2009 10:28 AM
Muzzy fuel pump
Where do you wire the external fuel pump that comes with the muzzy kit,I guess to the stock fuel pump wires?Also does anyone have any pics where they mounted there pump?
Just another foeteen!!!!!
zxbob
posted June 22, 2009 11:21 AM        Edited By: zxbob on 22 Jun 2009 19:21
Remove the stock pump and use the same wiring. I had put my pump in the lower
belly fairing.
I was working on the clutch in this pic but you can see the pump.
Bob
1badvespa1400cc
power junkie
posted June 22, 2009 01:08 PM
Thanks zxbob you da man!!!!!
bigwil
06 zx 14 turbo stage 3
posted June 22, 2009 01:39 PM
ill get some better pics tomorow but mine is at the back of my oil pan useing the back two bolts on the pan you can see the quik cont. goig to it
Photobucket
the three wires going to the stock pump / one is ground one is 12v thr other is a low voilt wire you will need to ground it is the flashing emtty senser wire
bigwil// going fast aint easy so turbo it
1badvespa1400cc
power junkie
posted June 23, 2009 07:56 AM
Will the fuel gauge still work,silly question,huh?
zxbob
posted June 23, 2009 02:43 PM
Yes !
Bob
bigwil
posted June 23, 2009 04:26 PM
heres more pic,
Photobucket
Photobucket
0.25334215164185 seconds processing time
