BIKELAND > FORUMS > ZX-14.com > Thread: Can you Believe this S..t! NEW TOPIC NEW POLL POST REPLY
Ninja ZX-14
posted June 18, 2009 07:31 PM
I'm riding my "06" 14 this past Saturday, cruising at about 60 mph when all of a sudden my bike starts to sputter real bad and loose power as if l had a fouled plug. A few seconds later l start to hear a clacking sound coming from the upper part of the engine. I immediately shut the engine off and coast to the shoulder of the highway. Bike's full of oil, no error light came on, on the dash, no white or black smoke ever came out of exhaust. No leaks anywhere. This is baffeling to me. You guys have any idea what this may be?
Ninja 14
posted June 18, 2009 07:36 PM
ground on PCIII? man my bike went bat sh*t crazy because of that ground
Ninja ZX-14
posted June 18, 2009 07:40 PM
I wish thats all it was but the sound came from inside the engine as if a chain or something was slapping inside. Bike has 15,000 miles on it. In imaculate conditon.
Ninja 14
posted June 18, 2009 07:41 PM        Edited By: Shane661 on 19 Jun 2009 03:41
Maybe the cam chain tensioner? So...what's the rest of the story?
Ninja ZX-14
posted June 18, 2009 07:50 PM
Well, I had a manual cam chain tensioner installed a few months after l bought the bike in 06. Bike has a 1417 JE piston kit, stock crank in it. Bike ran spectacular until this day when l was jus cruising at hiway speed.
Ninja 14
davej
posted June 18, 2009 08:15 PM
Don't jump to conclusions, what oil are you running? The manual if adjusted correctly won't be the problem, the piston kit..........no clue as the install or how it was done. What was the skirt clearance, the valve to piston clearance? Changing pistons is a biggie, the head gasket down to the tuning.
Triumph guy
Ninja ZX-14
posted June 19, 2009 02:21 AM
No, I'm not jumping to conclusions at all. Just trying to get some opinions on what you guys think this could possibly be before I take bike back to shop. Bike was never run on the track. Did roll ons every now and then. Other than that jus mainly cruised. Adams built this engine over 2 1/2 years ago. He's the expert on 14's , so l'm sure all clearances and tolerances are right on or else problems would have manifested well before now.
Ninja 14
JDC
posted June 19, 2009 05:28 AM
I don't like the sound of your sudden engine gremlin. Let us know what u discover.
posted June 19, 2009 05:33 AM
Has the cam chain tensioner adjustment been checked on a regular basis? You may have spontaneously changed your cam timing in a big way...ouch.
Good luck, let us know...
posted June 19, 2009 09:44 AM
sounds like the cam chain is out of adjustment and or let loose. i have had buddy loose a cam chain riding next to me and that's what it was like..... clatter, loss of power.....
Ninja ZX-14
posted June 19, 2009 10:29 AM
No, the cam chain has not been tested on a regular basis. I hope the timing wasn't chnaged the way that you are speaking of. I don't know anyone outside of drag racers or road racers, who ck their cam chain tensioner.
Ninja 14
Ninja ZX-14
posted June 19, 2009 10:30 AM
bigdtd, what did your buddy have to do once this happened to his bike. Give me some idea in as much detail as possible as to what l may be facing. Thanks!
Ninja 14
posted June 19, 2009 10:35 AM
The zx14 cam chain is only a 3 row, the busa has 4 rows...
Bill eason has been working to get us a better chain for the HD valve springs...
posted June 19, 2009 11:18 AM
Well, typically, it is racers who run a manual CCT. The stock part adjusts automatically for wear..but the manual needs to be checked occasionally. That is why the factory part is an automatic...it doesn't require much attention.
If you have a manual tensioner, it is always recommended that you check the adjustment from time to time. I am sure that if you call Adams they will tell you the same.
Hopefully nothing is hurt, but it is something to keep in mind in the future.
Ninja ZX-14
posted June 19, 2009 11:33 AM
Thanks Shane661 but I was always told how the hydraulic tensioner can at times not provid enuff tension and mess up a head. Every builder l know always suggested a manual cam chain tensioner. No one has ever told me about having to re check it, which is an inconvenience in itself if l have to do that, being that l don't tear my bike down after every few races or what not. Now l'm confused as to which way to go now because the head is definitely going to have to come off.
Ninja 14
Ninja ZX-14
posted June 19, 2009 11:36 AM
Dubious, what do you mean by 3 row and 4 rows? Are you saying that the 14 has a weaker chain than the Busa? I do have the HD valve springs in the head. That was recommended.
Ninja 14
posted June 19, 2009 11:38 AM
I know of plenty of reliable race bikes that use an automatic. It really depends on the bike and the application. But the manual definitely needs checked occasionally.
1badzx12r
posted June 19, 2009 12:20 PM
your screwed
posted June 19, 2009 01:01 PM        Edited By: dubious on 19 Jun 2009 21:04
Yes the busa has a stronger chain. I have HD valve springs too.
When I went to assemble the motor found the chain stretched quite a bit.... was another week wait for new chain... arghhh.
Bill has had a few bad chains come through his shop too.
Bill Easson also was selling modified zx12 auto but mechanical tensioner, that way if you lose oil pressure, you don't take out the top AND bottom end...
I tried a mechanical one from APE and it didn't even fit in the hole!
I decided to steer away from it all together.
iflyems
posted June 19, 2009 01:08 PM
That's because you had it upside down.....doh!!! j/k
When the hell you going to get off the computer and start running your bike?? OMFG....I almost can't stand it.
posted June 19, 2009 01:17 PM        Edited By: dubious on 19 Jun 2009 21:18
Paul, I'm at work right now,
But you could help.
I need to see some pics of your old bike, specifically the oil lines and where they were located on the adams pan.
You have a photobucket account or such I can browse?
Harry was supposed to email me pics but I doubt he compressed them and I haven't gotten the email... Its friday... HELP!
If you activate your IM's or email me at :
eldubois at telus dot net
that would be most awesome!
1badzx12r
posted June 19, 2009 02:31 PM        Edited By: 1badzx12r on 19 Jun 2009 22:31
enlighten me on that statement ..
iflyems
posted June 19, 2009 02:38 PM
http://s67.photobucket.com/albums/h300/iflyphi/
It's towards the back, enjoy.
posted June 19, 2009 03:02 PM
The zx12 tensioner is a coneventional tensioner, not hydraulic.
It will adjust automaticaly.
Need to machine .120" off the face of the mount, so it goes in further, and drop it in there!
Thanks buddy!
0.30392599105835 seconds processing time
