BIKELAND > FORUMS > ZX-14.com > Thread: What effect would -mild turbo bike timing NEW TOPIC NEW POLL POST REPLY
JDC
posted June 18, 2009 07:57 AM
For a 7 PSI turbo'd bike, ATP, Harry said that stock timing is ok for his kit at stage 1... mine is setup stage 1.
I have the timing -6.
Do you think changing to OEM timing would make a significant/noticably tellable difference in performance?
posted June 18, 2009 08:04 AM
Yes, a very noticable increase in power, as long as it doesn't detonate.
probably 15 RWHP increase
JDC
posted June 18, 2009 08:11 AM
Dubious, thank you!
posted June 18, 2009 08:17 AM
you are running Muzzy timing plate?
Try moving it back a bit at at time, and listen very close , especially under load , lower rpm and at max boost... be careful!
If you hear or feel any difference, that may be detonation, get out of it immediateltly and pull back on the timing.
Don't forget, fuel is seasonal, and usually worse in colder seasons...
JDC
posted June 18, 2009 08:29 AM
Got it.
1badzx12r
posted June 18, 2009 10:05 AM        Edited By: 1badzx12r on 18 Jun 2009 18:08
i can tell you -8 degrees is a killer on power .. i run -2 with 10lbs on avgas ...sometimes it mixed with pump gas 50/50
also had a 40hp loss on the dyno with -6 with 14lbs ..all we did was plug and unplug the EFIR
0.42216205596924 seconds processing time
