BIKELAND > FORUMS > ZX-14.com > Thread: Better looking swingarm? NEW TOPIC NEW POLL POST REPLY
Reckless
posted June 13, 2009 08:46 PM
Anyone here tried to fit a better looking swingarm on the 14?
I mean the stock arm is functional but I really like the look of the ZX 10 or ZX 6 arm.
Not looking to make it longer, just better looking.
reevesmreeves
posted June 14, 2009 05:06 AM
that's not a bad idea, but most guys go custom instead of swapping to another oem. if you find something that works, post it up. but then, you'd also be changing to different size axle, spacers, wheel and who knows what the hell else.
06 red 14
06 se 636
posted June 14, 2009 05:21 AM
Clearance issues with the subframe and fuel pump area of fuel tank, when suspension compresses, are likely with one of those arms.
dcjens
Wet side of Washington
posted June 14, 2009 11:07 AM
one i like is the ZRX 1200's for it's design in chain tightening. It has a cam excentric that tightens both sides evenly by turning the axle. The align by lines seems so outdated. I haven,t done any research to see if any or all of that fits the 14. just an idea
Black 06
reevesmreeves
posted June 14, 2009 11:11 AM
that sounds like it help out a lot. my bike rode a ton better after replacing the rear sprocket just because the chain needed adjusting so bad. the tight spot would get tighter and the loose spot would be within spec. i hate that!
06 red 14
06 se 636
LAB3
posted June 14, 2009 02:43 PM
A new EKZZZ chain is worth the extra $$. OEM 17 front and a Driven steel 43 tooth
rear (Black) works great on the street. I use WD40 and wipe off really good as I
have polished my rims and have a stock chrome plated swing arm that I need to install.
reevesmreeves
posted June 14, 2009 02:48 PM
sounds good lab! we need pics of the chrome arm : )
06 red 14
06 se 636
posted June 14, 2009 03:23 PM
Swing arm flex on the zrx1200 and 1100 is really really bad ..So bad that a few zrx owner have swapped to a zx14 swing arm if that tells you anything..
Reckless
posted June 15, 2009 02:34 PM
I think you may be right Dubious. That fuel pump seems to interfere with everything.
I may play around with this over the winter if the 2010 ZX 14 looks the same as what we have now. Just looking for ways to make the bike better and a little unique.
ZX11D
Internet Police
posted June 15, 2009 03:04 PM        Edited By: ZX11D on 15 Jun 2009 23:04
....Swing arm flex on the zrx1200 and 1100 is really really bad ..So bad that a few zrx owner have swapped to a zx14 swing arm if that tells you anything..
Plus it must be the most hideous swing arm that Kaw ever produced, so no help in the "looks" department here
'94 ZX-11
'07 ZX-14
0.28469085693359 seconds processing time
