BIKELAND > FORUMS > ZX-14.com > Thread: 08 injectors NEW TOPIC NEW POLL POST REPLY
bigwil
06 zx 14 turbo stage 3
posted June 11, 2009 09:21 AM
08 injectors
im looking for a set of 08 injectors does any one have a set and has any one tried this yet ive got my stock 06 and want to put some nitros w /hi flo fuel pump and a arm on
bigwil// going fast aint easy so turbo it
pissear
Professional Cockis Slap Peer
posted June 11, 2009 03:39 PM
Between both, it is slight. If you take the angle away, it might be half that. Truly subtle differences. Not what you think. I was not impressed, but the '08 would be my choice with the 20° throttle body angle.
posted June 11, 2009 05:38 PM        Edited By: dubious on 12 Jun 2009 01:39
the 08-09 are supposed to be 25% larger... 420 cc
06-07 are 330 cc
as I was told anyway.......
pissear
posted June 11, 2009 07:02 PM        Edited By: pissear on 12 Jun 2009 03:04
I pinched a piece of aluminum rod, made it the length of the injector = Same-Same.
I bent a piece of aluminum welding rod around the widest part of the injector body, measured the other one = Same-Same.
I measured the intake pots over the injector so as to see more volume up 25% as in proportion to the volume increase to flow that much more = Same-Same.
I did not measure fuel pump volume up 25% or more so as to increase the flow 25%. Fuel pump design changed, but did the pressure of 44 PSI as base output increase?
The '06 has a blue body with, "EAT286" as the markings on the injector body.
The '08 has a greed body with, 2870772 as the body markings.
These are I believe Bosch injectors; when I removed the actuator, I may have seen the name? Do not quote me on the brand... Believe the rest is the numbers will point the difference in either a 10 spray or a 12 hole injector spray head is the only difference. Unless you can find the parts matching flow or increase of flow rate between bodies.
davisag
posted June 12, 2009 02:30 PM
hi
i fittted the 08 injectors to my 06 tuned model, and with 06 ecu, pump etc, they flow less fuel than the 06 injectors, so looks like 2 extra holes but even finer spray
when i set them up on the dyno big numbers had to be added to the power commander rangeing from plus 20-30 across the range
have noticed an improvement in fuel consumption but no power gains
posted June 12, 2009 08:21 PM        Edited By: dubious on 13 Jun 2009 04:22
Wow, that is complete opposite of what I have heard.
Good thing I put an extra 60lb injector in every hole for mine.......
pissear
posted June 12, 2009 08:28 PM        Edited By: pissear on 13 Jun 2009 04:31
Data was more or less WOT my assfactor found out and concluded to. No appreciable gain between either body angle and/or spray hole, using the '06 and '08 to find out without access to a dyno.
0.22764682769775 seconds processing time
