Nelson Taylor
posted June 10, 2009 08:10 AM
Removing a TRE???
Hey guys I am going to be helping a buddy with a bike he recently bought.
It has the flies removed and a TRE installed. He would like his gear indicator back.
Where exactly is this TRE located on the bike and whats all involved in removing it.
Thanks in advance....
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
joemugg
posted June 10, 2009 08:15 AM
The plug that the TRE intercepts is on the left side of the bike in the same bundle that a PowerCommander plugs into. Its a white triangular plug with three wires in it, and usually the TRE is black and a little larger than a AA battery and inline with that plug.
'97 GSXR600 street sweeper
starchild
posted June 10, 2009 10:35 AM
joemugg may be correct on his bike.on my set up the connection is a light green adapter hanging right above the sprocket cover it is a 4 pronged adapter.it is the gear position sensor'.
jay
Nelson Taylor
posted June 10, 2009 12:11 PM
Okay atleast I know where to start looking...
Best #'s
1.54
4.03
6.02 @ 121mph
Douglas Home
posted June 10, 2009 12:47 PM
if its Ivans tre go to his site andfollow the directions in reverse ,www.ivansperformanceproducts.com
there is different ones/ one stops decel pop and one tricks the ECU into thinking that you are in a different gear
I had a tre008 that I removed and still have no decel pop .
Doug Mackay Australia
TooHype
Go Hard or Go Home !!
posted June 10, 2009 04:56 PM
quote: if its Ivans tre go to his site andfollow the directions in reverse ,ivansperformanceproducts.com
Nelson Taylor
posted June 11, 2009 03:16 PM
Looked on his site and I dont see any instructions on how to install.
If some has there instructions sitting around please post. or shoot me an email.
nelsontayloriii@yahoo.com
Best #'s
1.54
4.03
6.02 @ 121mph
pissear
Professional Cockis Slap Peer
posted June 11, 2009 03:31 PM
Nelson, Think like this. Go to the left of the bike down by the top of the sprocket cover. There are two connectors. One is a triangle with 3 wires. That is the speed sensor, so that is not it.
See the green connector with the 4 wires? One is the kick safety wire. One is ground. One is light green. One is black with a red tracer or vice verse on the black/red.
The tre will hook up to either the light green or the black/red. Whatever is sticking out and hooked to the tre, you undo the wires used from the tre connector.
You then match that one wire back into the stock connector. Have the tab up so it does not come out. You are back to the trans number gears.
AZ ZX14
posted June 11, 2009 04:29 PM
quote: Looked on his site and I dont see any instructions on how to install.
Hope this helps.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
Nelson Taylor
posted June 11, 2009 07:44 PM
Good looking out fellas I had the TRE off the bike earlier just couldnt figure out what connects back together to stock. This one has a white connector mixed in with those black and green connectors.
Thanks for your help...
Best #'s
1.54
4.03
6.02 @ 121mph
pissear
posted June 11, 2009 10:33 PM
Reverse Engineering from the bottom UPizzass:
Dis Prod is for off road and race use is "going to go slower only."
Wezza not is ah responsible for any con sea sequential damage going is if the factory says it is good to go.... I have to say it will damage yours wit my deal. NOT!
Use is got a code on the dash is once warranty finds out tampering? Use is dis product is a violation of what? Tuned in the redundant like the emissions moved? It is so rich it is not ride-able kind of spewing emissions? How does less hp spew more emits data one went right over my head.
When the subthrottle plates are removed, she ah goanna run ah like, "excessively lean" is hole a piston and burn a skirt it is that lean? Excessive like ah data? Mine is fine ill say.
Dis ear is going to limp you one more time, so we still are going to cut the fuel is same redundant is less HP is no ratio to pop is cold vs. hot to pop the limp.
Social Science at it's best. Junk in a box is my junk science out door behind number 2 is pull the zipper down is here it cums.
http://www.youtube.com/watch?v=6-QrPm6YpdQ
