BIKELAND > FORUMS > ZX-14.com > Thread: Adding data logger - need ECU plugs NEW TOPIC NEW POLL POST REPLY
rtbain
old, fat and slow
posted June 08, 2009 03:56 PM
After reading, and drooling, over many of the modifications on this site I have opted for once in my life to take modest approach.
First step was to get a baseline (no bs) run after break in. Stone stock with 720miles on the clock it made 148bhp (corrected) at 175mph (dyno speed).
A speedo-healer is next then Innovate's DL-32 data logger. Not having the funds for extensive chain logging streams I am opting for:
RPM
TPS
Acceleration
Wide band O2
And probably air box pressure (what the hell)
All easy to get to via ECU inputs. Problem is I don't want to hack up my stock wiring harness. Does anyone know where to source stock ECU plugs? Male and female.
Randy
  Ignore this member    Click here to visit rtbain's homepage.
JDC
posted June 08, 2009 04:48 PM        Edited By: JDC on 9 Jun 2009 00:49
I found the FI harness main to sup harness connectors at Senko, El Paso Tx. They are bulk order only, but they do a lot of connectors.
If you know a company that already plugs into the ECU slot, call them and ask for their part no and manuf... that'll help a lot.
Hopefully someone will come by with more specific and better info.
0.32888412475586 seconds processing time
