BIKELAND > FORUMS > ZX-14.com > Thread: Timing Suggestions NEW TOPIC NEW POLL POST REPLY
cycle junkie
posted June 08, 2009 09:39 AM
Timing Suggestions
Has anyone with a dynojet ignition module created there own timing curve?
What should it look like?
Where would you want the advance. (Throttle position, RPM)
http://www.performancephotos.com
"Any society that would give up a little liberty to gain a little security will deserve neither and lose both."
-Benjamin Franklin
  Ignore this member    Click here to visit cycle junkie's homepage.
Bluebyyou
Gettin My Curve On
posted June 08, 2009 11:09 AM        Edited By: Bluebyyou on 8 Jun 2009 19:10
I wanna watch this for an answer also.
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
posted June 08, 2009 11:12 AM
Haven't seen anyone around here who has experimented with this...
87gtNOS
posted June 08, 2009 05:10 PM
On my Yamaha APEX snowmobile (R1 bike engine more the less) I have the timing module.
One of the things about it's ignition is it pulls timing from 10500+ up. Rev limiter (stock) is 11200.
Another thing to remember is, with the snowmobile, WOT takes you instantly to FULL RPM. Full rpm for me is 10700.
Whereas, on a bike, you go WOT and the motor will accelerate through the rpm range, hence creating more of an environment for detonation.
On the sled I add 5 degrees from 10500 to 11250 rpm. I have 2 to 3 degrees added throughout the rpm range.
Timing = torque. I would suspect that 4 to 6 degrees in the mid rpm range would be most noticable. Fuel will need to be added also.
01 ZX12R
0.23274803161621 seconds processing time
