BIKELAND > FORUMS > ZX-14.com > Thread: PING Dubious! NEW TOPIC NEW POLL POST REPLY
FastestBusaAround
I eat Fish...
posted June 05, 2009 01:46 PM
PING Dubious!
Question, on the Tracs 6” over swingarm I got from you...my chain sits right on the teflon pad, probably because of the 16/43 setup. I was wondering - should I be dumping the 16/43 and just go to a 17/44 or 45 or 46 setup instead to get the chain up off the teflon strip? I get light banging constantly that I can feel through the frame and am concerned about heat/wear on both the arm and the chain. What do you think? To date, I have about 6k miles on that setup but no issue, however I'm thinking it can't be good. Smokin, you can answer too!
FYYFF!!!
posted June 05, 2009 01:52 PM
Is it wearing the pad?
Check the return side too.
If it is not wearing the pad, or touching thearm anywhere I would not be concerned.
I was running 17-44 gears with the arm.
to get 16-43 ratio you would want 17-47 ,
17-47 would require longer chain, or moving the axle forward about 1-1.5 "... which I know you would like for street traction, handling and wheelies...
LMK if you need anything.
Got my number still?
posted June 05, 2009 04:02 PM        Edited By: smokinZX14 on 6 Jun 2009 00:03
Fast don't sweat it it's fine ....Mine with 16 /41 did the same thing ....It's a little noisy over bumps or on offf throttle at low speeds but it will not hurt a thing .. Even with 17/47 it's still going the hit the wear pad ( that's why it's there ) ...
FastestBusaAround
I eat Fish...
posted June 05, 2009 07:46 PM
Thanks to both Dubious & Smokin'. I was concerned, but hearing this from you guys gives me the warm and fuzzies now. Lyle - your cell must have changed as I called it today and some immigrant lady said I had the wrong number. I told her she wasn't allowed to take over your old cell, no matter what. I have your other two numbers, which I believe are good.
FYYFF!!!
0.42480897903442 seconds processing time
