BIKELAND > FORUMS > ZX-14.com > Thread: Question about speedo and accuracy NEW TOPIC NEW POLL POST REPLY
kaw now
posted May 29, 2009 09:59 AM
Talking to Beemer owner he claimed that the speedo head can be modded cutting a resister and return the bike to complete accuracy. That was on a bmw of course and they make police bikes so they probably need a calibrated speedo. Does any one know if this is possible with the kaw? I realize of course that depends on stock gearing or maybe they have some kind of calibration possible. Not sure if all the info comes from the ECU or what.
Compton
posted May 29, 2009 10:00 AM
just get a speedohealer.
b.w.
posted May 29, 2009 03:16 PM
and set it to -8% with stock gearing
masszx14
A mind beside itself!
posted May 29, 2009 06:00 PM
You can always get a 190/ 55 rear tire and that will almost compensate
for the 8% error. The taller tire is great for the street but really bad for the
dragstrip... just take it from there.
universal@mind
kaw now
posted May 29, 2009 08:59 PM
Speedohealer seems to be the consensus. That's the easy out and costs money. Isn't there a some sense of adventure anywhere? Maybe someone has a broken speedo to take apart. I know its fairly cheap and is adjustable, the speedohealer, that makes too much sense. Thought about the 190 55 tire but at tire time none were available for the brand I wanted. Which is to say the cheaper tires. You see the common thread of cheapness here. I'll go one further if every one promises not to laugh. I used some citrus cleaner and cleaned my old air filter. It did a nice job and now use it. But that could be another thread.
TooHype
Go Hard or Go Home !!
posted May 29, 2009 09:29 PM
What should the speedo be set at for 16/41 gearing?
Compton
posted May 29, 2009 11:09 PM
used clusters with good LCD screen go from 250-400 depending on miles.
speedohealer is 100.00 its cheaper then getting a new cluster to mess with.
b.w.
blackbullet76
posted May 30, 2009 05:11 AM
Get a speedohealer and you can adjust your speedo for whatever gearing you decide to run. Only takes a minute to calibrate. I love mine.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
Douglas Home
posted May 30, 2009 05:12 AM
TooHype set your speedohealer at -10.8% calibration for 8% speedo error and 16/41 cogs!
This is what I did (off their website) but havent checked with a GPS.
Goodluck.
Doug Mackay Australia
posted May 30, 2009 07:48 AM
the difference is 16/17 =new vs stock= 1.0625
therefor the gearing change is -6.25%
stock it is off by -8%
14-15 % will correct it, but if you want to be able to hit the rev limiter in 6th and get everything out of it you will need to go -20%
The speedo would obviously be reading 5% lower than actual at -20% setting
Newbusa
posted May 30, 2009 09:15 AM
Why is a 190/55 tire bad for the dragstrip?I have a BT016 on my bike with those #s,
masszx14
posted May 31, 2009 06:12 AM
The 190/ 50 will give you a wider contact patch when the bike
is upright and the 190/ 55 will give you a larger contact patch
when the bike is leaned.
universal@mind
joemugg
posted May 31, 2009 05:47 PM
SpeedoHealer rules! I never used the old one version, but the new version has two banks that you can set separately in case you commonly switch gearing, the ability to quickly switch between MPH and KMH (to eliminate top speed limiter) and it has a remote button to recall top speed. I've got mine set at -14% with my -1 front sprocket and it uses the KMH scale to display MPH so I'm putting about 40% fewer miles on the odometer. Get a SpeedoHealer, Dude, they're more fun to play with than the cluster.
'97 GSXR600 street sweeper
Newbusa
posted May 31, 2009 05:53 PM
Ahh, I see.
kaw now
posted May 31, 2009 10:03 PM
Good point about the top speed recall feature. I like that one. Kaw should put that on stock like some other bikes Triumph for 1 I believe.
Port_Angeles_NINJA
posted June 01, 2009 01:02 PM
There wouldn't be a similar mod for the 14 speedo. The signal from the speed sensor (pin 13 on the cluster connector) is a pulse train. The frequency of the pulses tells the cluster how fast the bike is moving. To change the indicated speed you would either have to modify the programming in the cluster that calculates speed, or fool it by changing the frequency of the pulses going into the cluster. The latter is exactly what the speedohealer does, and a hobbyist would be hard pressed to do the same thing as cheaply.
Red/Black 85' GPZ900
Blue 07' ZX14
TooHype
posted June 04, 2009 11:38 AM
So what is the exact setting for 16/41 gearing?
posted June 04, 2009 02:10 PM
The exact setting, or close as its going to get for 16/41 is -14.25 to -15%
That will limit your top speed to about 160 mph with an accurate speedo.
Stock geared literbikes will run away on you at top speed if you do not correct for it and the error.
87gtNOS
posted June 05, 2009 03:45 AM
This is how I had my ZX9 set too!! Bang on with GPS! Then I took it off the ZX9 and put it on the 14 and left it as it is!!
01 ZX12R
Zuluninja
posted June 05, 2009 10:11 AM
so, to squeeze out more you have to set it at a higher negative value? haven't had a chance to let her rip to the end of the throttle yet, I installed the speedohealer on wednesday. Oh and toohype, just go to the heal tech website, they have a calculator for gear changes.
87gtNOS
posted June 05, 2009 10:55 AM
My bike hit something like 320 kms on the dyno...the dyno guy was surprised as he was watching the dyno's speedo and the bike went past 300!!
This was with healer set at 8%, so at 300 on MY speedo, the dyno was around 320 kms. The bike thinks it's going only 300 and that's were the limiter hits!!
01 ZX12R
TooHype
posted June 05, 2009 12:34 PM
Was that stock gearing and tire size?
87gtNOS
posted June 05, 2009 12:42 PM
TooHype, yes it was stock gearing.
01 ZX12R
posted June 05, 2009 01:11 PM
I kept a most accurate speedo healer on mine
87gtNOS
posted June 05, 2009 01:37 PM
LOL!!!!!!!!!!!!
01 ZX12R
0.23099613189697 seconds processing time
