BIKELAND > FORUMS > ZX-14.com > Thread: kill switch NEW TOPIC NEW POLL POST REPLY
hardatit
posted June 03, 2009 07:08 AM
kill switch
I was wondering if anyone made a kill switch (tether) with a addition button to hook air shifter to instead of using the horn. I have my horn switched were I can have a horn or switch to air shifter. Every once in a while when using the horn it back feeds somehow and barely kills the engine. Would like to go to another switch.
posted June 03, 2009 07:18 AM        Edited By: Shane661 on 3 Jun 2009 15:20
Sounds like the problem is in the toggle switch that you use to arm and disarm the shifter. With good wiring and a good switch there should be no possible way for the kill box to be activated when the horn is enabled.
You can get billet bar mounted push button assemblies from Pingel.
pazx14rider
posted June 03, 2009 08:07 AM
photo assist
0.2303900718689 seconds processing time
