BIKELAND > FORUMS > ZX-14.com > Thread: What Oil to use for ZX14?????? NEW TOPIC NEW POLL POST REPLY
BigBadZX14
posted June 01, 2009 08:32 AM
Need to know what I need to take off to change the oil on my 08'ZX14. I know if I need to take off any fairing and or lift the bike up a little to put a pan under to catch the oil. And where the drain plug in. What oil do most of you guys use? Semi-Synthetic or Full Synthetic? Are there any special oil filter wrenches to use, or can you use something else? Thanks for your input.
08' ZX14 Midnight Saphire Blue, Two Brothers Slip ons, PMR Tether Cut off Switch, Fender Eliminator Kit,
epd345
posted June 01, 2009 08:38 AM
I use the filter tool from Napa and Napa gold oil filters and I do not have to remove any fairings. I am able to reach in to remove the filter. If your bike is broken in 600+ miles you can switch to sythetic if you like. I went to 1700 with standard oil(two oil changes)and then switched to sythetic. I use Royal Purple M/C 20w50 but what you use and buy is really up to you. Don't forget to change the crush washer on the plug every second oil change.
zx-twitch
the dude abides
posted June 01, 2009 08:55 AM
I use amsoil and K&N filters. I love the 14 for its ease of oil change. no need to take any thing off or lift the bike.
zxbob
posted June 01, 2009 09:32 AM
"Red Line oil" ~ factory filters !
Bob
Niner9
posted June 01, 2009 11:27 AM
amsoil 10/40 full synthetic, K&N filter....
Akro slip ons, Scotts Damper, Hel Brake & Clutch lines, Vortex Rearsets, Sato Frame Sliders, Power Commander, Custom Map, Flies Removed, BMC Race Filter, Marchenisi Rims, Corbin Seat, Ventura Pack Rack, Pazzo Levers, Zumo 550 GPS, Passport Radar Detector, Throttle Miester Cruise,
Wheelie
Old Man
posted June 01, 2009 11:38 AM
whats a tre?
wee
duncan
posted June 01, 2009 12:15 PM
RED LINE OIL FOR ME AS WELL
johnsonzx14
posted June 01, 2009 02:53 PM
Rotella T syn....... good stuff
THEMADKAW
posted June 01, 2009 02:56 PM
motul 300v!!!
117 in a 30
posted June 01, 2009 03:42 PM
redline oil purolator pure1 filter
Rideharder
posted June 01, 2009 03:53 PM
Features and Benefits
Fully synthetic, high-performance 4-stroke engine oil for motorcycles
Provides optimum protection against engine wear under the most grueling extreme-temperature racing conditions
No slipping of the wet clutch
Extreme temperature and shear protection
http://www.cyclegear.com/spgm.cfm?L1=&L2=&L3=&L4=&item=TUC_98-0034_G
Mobil 1 Oil Filter
  Ignore this member    Click here to visit Rideharder's homepage.
posted June 01, 2009 04:02 PM
Purolator pure1 filter , Mobil One 10w30 .....Yes car oil !!!! and NO my clutches don't slip ...
butterthegreat
posted June 01, 2009 06:19 PM        Edited By: butterthegreat on 2 Jun 2009 02:20
Shell Rotella T 5w-40 full synthetic....30k using that oil with no problem.
The trick is to make sure you use oil with NO friction modifiers....
LAB3
posted June 01, 2009 06:30 PM
Purolator part# please. Is it the 2.5 inch short filter?
zerotahero
posted June 01, 2009 06:33 PM
AMSOIL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 10/40
zx-twitch
the dude abides
posted June 01, 2009 08:46 PM
i run amsoil 20/50. it gets really hot here in phoenix
Sticks_n_Stones
posted June 01, 2009 09:45 PM
0W-20 Mobil 1 car oil, and whatever filter I find available.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
posted June 01, 2009 10:01 PM
MOTUL Synth <---track bike
AcadianaZX
Advertiser
posted June 01, 2009 11:24 PM
100% Synthetic Amsoil 10w40. Cooler running, best shear strength stability, holds its viscosity in high temps.
TooHype
Go Hard or Go Home !!
posted June 01, 2009 11:55 PM
+1
Douglas Home
posted June 02, 2009 12:07 AM
cold press extra virgin ........good for cholesterol too!
Doug Mackay Australia
TooHype
posted June 02, 2009 12:10 AM
VASELINE !!
Douglas Home
posted June 02, 2009 12:15 AM
Toohype ,try strawberry flavoured gell , I use it on my chain and it makes cleaning it a
delicious turn on!
TooHype
posted June 02, 2009 12:27 AM
OOOh no I use good ole KY on my chain
LAB3
posted June 02, 2009 04:01 AM
+1
do you know the Purlator Pure 1 part # ? I use the OEM Kaw 2.5 inch filter.
Louis
All times are America/Va [ This thread is 5 pages long: 1  2  3  4  5     Next» ] < Previous Thread     Next Thread >
0.24223399162292 seconds processing time
