BIKELAND > FORUMS > ZX-14.com > Thread: motty afr tuner NEW TOPIC NEW POLL POST REPLY
bruno nadeau
posted May 20, 2009 02:48 AM
motty afr tuner
after riding the bike(06 zx14) for about 5000 km with the motty i can tell that this device is working for reel.after building a afr map at 14,7 on low load (to about 130 kmh in 6) and 12,9 for power and some other number like 13,5 12, 12,5 14, for smooth transition .the throttle is a lot smoother the bike look to pull harder(have to check it) i went from 282 km max to 347 max on a gas tank before full emty come on wen normal street riding ( 100 to 140 kmh on back road.with the dataloger i can see how the mapping progres and it is faster than i hope.to get 12,9 on full throttle from 5000 rpm to 11000 rpm it take me 5 pass on 4 gear to build a 12,9 from the stock map that jump up and down from 12.3 to 13,1 on the same range.lot more option like switching from 2 differents map on the fly.........the unit can datalog afr, tps, engine temp, speed. target afr.rpm,in witch map you are.with the dataloger you can see witch map work best for your bike you can see acceleration on time in0.000 second useful to test different maps.i like it mutch more than my power commander.i forget to tell that the afr tuner is always updating the map as you ride for otside temp air filter coming dirty and so on.and you always tune in reel world with ram air in fonction.there is a function for NOS to.
bruno nadeau
Ricksgsxr
posted May 20, 2009 01:31 PM
No personal use but do follow 'stocky" posts on gixxer.com and the only reason I visit there he has had good success and praise for it.
posted May 20, 2009 07:03 PM
Nice!
I remember asking if he was going to make one for the zx14, but at the time he didn't have plans for nos, so I never bought one...
It sounded like a real nice unit.
0.23463702201843 seconds processing time
