BIKELAND > FORUMS > ZX-14.com > Thread: ZX14 Shock NEW TOPIC NEW POLL POST REPLY
bsebastian
posted May 18, 2009 09:08 AM
ZX14 Shock
I have a 08 ZX14 and the guy I got it from made the shock way to stiff. I weigh 160 suited, stretched to 64, 17/44 gearing, and set at lowest setting on lowering links. I raced it for the first time this weekend and it bounced down the track. How much of the threads should be showing to get me closer to get it adjusted right and turns on upper and lower screws? Any info would be great! Thanks.
14nooby
posted May 18, 2009 09:12 AM
I have never heard of it being too stiff. I am the same weight and mine is at the stiffest setting and my tire still rubs the fender every pass.
Wheelie
Old Man
posted May 18, 2009 09:18 AM
turn the settings all the way out.
wee
Sticks_n_Stones
posted May 18, 2009 09:24 AM
Sounds like an aftermarkeet spring. Take a pic of it, and see if there is any name or number on it, I'm sure someone would trade you for a lighter aftermarket spring, or would buy it off you. They are around $120 for Racetec rear spring FYI.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
posted May 18, 2009 09:36 AM        Edited By: dubious on 18 May 2009 17:37
If it is bouncing, you need more rebound damping, you will need to turn the adjuster in to get more damping and prevent bounce.
If it compresses too fast , you need more compression to slow the compression, by turning the compressiona adjuster in
adjusters:
In is to increase, out is to decrease.
Spring:
Tighten to stiffen, loosen to soften
If it has adjustable threaded links, they are used to set ride height, and will not change suspension control
posted May 18, 2009 03:06 PM
has to be
bsebastian
posted May 18, 2009 06:38 PM        Edited By: bsebastian on 19 May 2009 02:39
Thanks for the info. I will see if this works! ( I never rubbed the inner fender.)
Bently
2012 14r In Blue and no Mods!
posted May 18, 2009 06:42 PM
Well on the track you where at you probably could not leave hard enought to rub the inner fender. get to a decent track so you can see what it is doing.
LLcooljebb
Upgrade I Must
posted May 18, 2009 07:20 PM
http://www.sportrider.com/bikes/146_suspension_settings/index5.html
Shane posted this link awhile back. Check the pre-load, but I suspect aftermarket spring as well.
"no time to be void or save up on life
you got to spend it all.."
0.21493601799011 seconds processing time
