BIKELAND > FORUMS > ZX-14.com > Thread: Starter relay buzzing, NEW TOPIC NEW POLL POST REPLY
3000psi and falling
posted May 13, 2009 05:59 AM        Edited By: 3000psi and falling on 13 May 2009 14:03
My bike is starting to make a buzzing sound from under the back of the seat when I try to start the bike, it does not happen all of the time. But when it does the starter will not engage, I found that I can push the starter button a few times to got the starter to turn. Is the relay going bad? (The battery is good at 12.5 ocv)
posted May 13, 2009 06:01 AM
That or the battery....what is the voltage indicated on the dash?
3000psi and falling
posted May 13, 2009 06:05 AM
12v key on, 14v running. The battery seems to be in good health.
posted May 13, 2009 06:07 AM
The relay shouldn't be worth much, the other thing to check is for tight , clean battery connections
3000psi and falling
posted May 13, 2009 06:09 AM        Edited By: 3000psi and falling on 13 May 2009 14:14
Yes, they are clean and tight. But I will take a closer look and sand and apply batt term gel to them now.
kawasakijockey
posted May 13, 2009 06:14 AM
+1. Check the starter relay connections. The relay could be going bad.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
3000psi and falling
posted May 13, 2009 06:35 AM
Found it, I did not look closely enough at the negitive batt term. It has some corrision on it, more that I would have figured on a less than a year old bike. Fixing it now, thanks for the help.
3000psi and falling
posted May 13, 2009 07:22 AM
Works like new!
posted May 13, 2009 09:22 AM
0.23390412330627 seconds processing time
