makenna
posted May 12, 2009 04:44 PM
Speedhut Custom Glow Gauges
So I finally got around to installing my Speedhut custom glow gauges. I have only had these a year so I figured it was time. Some of you may also have experienced having difficulty reading your gauge while riding at night. Now with these gauges it is much easier to see the cluster in low light.
I had a custom set made as the Canadian ZX-14 doesn't come with both KPH & MPH on them., making your speed guess work while touring in the States.
English is the only language that matters.
posted May 12, 2009 04:57 PM
How much do they cost? Lloks good!!
posted May 12, 2009 05:22 PM
look really good
posted May 12, 2009 07:12 PM
nice!
ZXLNT
posted May 12, 2009 07:29 PM
Pimp yo!!
LLcooljebb
Upgrade I Must
posted May 12, 2009 07:48 PM
Should've come from the factory like that! Just added one more item to the "To Install" list!
"no time to be void or save up on life
you got to spend it all.."
makenna
posted May 13, 2009 01:46 AM
They weren't expensive at all, only $79.95
I agree, all the North American bikes should have come from the factory that way.
You can check them out at - http://www.speedhut.com/custom_gauge_dial_products-auto-Kawasaki.htm
LAB3
posted May 13, 2009 02:25 AM
They look Great, seen them before. You installed better than the last ZX-14 I looked. Hard to get them "Centered" on stock face.
WindSwordNinja
posted May 13, 2009 07:03 AM
Were they very difficult to install, and where did you tap into for power?
2014 ZX14 Black and Green
2008 ZX14 Black and Red SE
1986 ZX1000R Black
"Faster, faster! Faster would be better!" (Serenity)
makenna
posted May 13, 2009 07:33 AM
Very easy to install, hardest part was geting the needles off. They separate right down at the base, the steel shaft comes out with the needle.
Went into power using the marker light above the headlight.
