BIKELAND > FORUMS > ZX-14.com > Thread: Can I get into the 8s on a stock engine? NEW TOPIC NEW POLL POST REPLY
madnessracing
Vmax and Busa Beater
posted May 10, 2009 05:48 PM        Edited By: madnessracing on 11 May 2009 01:48
07 14 with 16-43 gearing
V&H Sidewinder
PCIII tuned on 89 pump gas
sitting at 63 1/2
no air filter
air shifter!
If not what else can i do without touching the motor to get into the 8s? Thanks in advance guys.
Shorty's Performance
Team Madness Racing
Wheelie
Old Man
posted May 10, 2009 05:57 PM
where are you?
wee
madnessracing
posted May 10, 2009 05:58 PM
Los Angeles CA
Team Madness Racing
Wheelie
Old Man
posted May 10, 2009 06:00 PM
any experiance drag racing? what do you weigh?
wee
Compton
posted May 10, 2009 06:21 PM
i dont know if you can, but the bike has the power too.
b.w.
madnessracing
posted May 10, 2009 06:24 PM
My Best is 9.21@149 my 60ft is 1.44-1.47
Team Madness Racing
kaw-rick
posted May 10, 2009 06:26 PM
Slap on some nos. Gaurantee you will go 8s.
Wheelie
Old Man
posted May 10, 2009 06:29 PM
1.44 aint no rookie on a 60', maybe if you race on Smokins track, downhill, below sealevel, strong tail winds, you can do it.
wee
madnessracing
posted May 10, 2009 06:31 PM
Trust me I thought about it a lot but I would really love to do it stock
Team Madness Racing
Wheelie
Old Man
posted May 10, 2009 06:33 PM
21 is a long way from 99, good luck
wee
madnessracing
posted May 10, 2009 06:38 PM
A few people have done it so why not me? I know the westcoast suck with the air and elevation, humidity and all that stuff but maybe others mods that I dont know could help me reach my goal!
Team Madness Racing
Wheelie
Old Man
posted May 10, 2009 06:41 PM
not doggin you Bro, thats just a lot of time to make up,
wee
02zx12rbob
posted May 10, 2009 06:43 PM
Lil luck and lotsa seat time.. Good Luck !
Wheelie
Old Man
posted May 10, 2009 06:44 PM
did I miss your weight?
wee
madnessracing
posted May 10, 2009 07:17 PM
180 suited!
Team Madness Racing
LLcooljebb
Upgrade I Must
posted May 10, 2009 07:57 PM
P90X for you and Shane's thread for the ZX...re-map with race gas...possibly an auto-shift (eliminate early/late shifting).
"no time to be void or save up on life
you got to spend it all.."
posted May 10, 2009 08:29 PM        Edited By: smokinZX14 on 11 May 2009 04:59
180 pounds ... Well you can get close ... Might pull it off in Sac town ( 98 Feet above sea level ) in the fall or spring .... If you can get your 60s in the high 1.30s and run some MR9 with brocks track map and no air filter you may pull it off in LA ..
In FL this time of the year i can keep mine in the mid 8.90s on pump gas , the 8.80s come in the winter, fall and spring... I'm 150 pounds and it takes a lot work to keep mine in the 8s in this heat and humidity..
madnessracing
posted May 11, 2009 12:50 PM
Thanks smoking I will try to do what you say.
Team Madness Racing
posted May 11, 2009 01:15 PM
I would say a 9.05 with mr 9, 16-44 gearing with the elevation and or heat...Use a Michelin soft or a pirelli super corsa sc0 with 25lbs. and Practice, practice, practice...
kawasakijockey
posted May 11, 2009 02:47 PM
I would say you can do it but you will have to be over 150mph so you will be waiting on good air to get it done. There was a guy on here, Racers, that got to 9.02 (I think) out there in Cali. He was 205lbs unsuited and ended up destroying his bike before he got the 8. That is a goal of mine too but 235lbs suited is gonna be a hell of a job because our air is only good here for a very short time. You weigh 55lbs less than me but I have run .04 faster at 152 mph in cold air, 55lbs is two tenths in your favor. It aint easy but it is a very realistic goal if the air conditions are right. Good luck and do your best.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
madnessracing
posted May 11, 2009 05:39 PM
Thanks Guys!! I've been drag racing bikes for about a year now so I think I have a lot more left in me too I dont know we'll see.
Team Madness Racing
00Busa
Trying to go FASTER !
posted May 12, 2009 03:15 AM
I will be able to tell you soon, there's a new 1/4 mile track opening here in SC and they're having a Bike Day on the 31st. I should be able to get in enough runs to see some EIGHTS if I'm able. I can run 5.70s real consistant in the 1/8th so I feel that 8.90s should be within reach. I weigh 175 lbs.
'00 Busa / '06 14 /
IT AINT BRAGGING, IF YOU CAN BACK IT UP !
posted May 12, 2009 03:48 AM
What map/exhaust are you running? 152 mph is a lot at your weight!
kawasakijockey
posted May 12, 2009 03:56 AM
Alienhead and Street Map. The Track Map has netted one 153mph pass but only a 9.20 et. The 9.17 was done with the Street Map.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted May 12, 2009 05:13 AM        Edited By: Shane661 on 12 May 2009 13:14
Brock's told me that the track map is really for MR9...they said to run the street map unless I run MR9/11.
I see a lot of people running the track map with pump, but they advised me otherwise...
I'm still surprised at your mph. I should be able to pull 153-154, I would think?? My setup bike/rider is probably 70 lbs. lighter than you. Shortmeg, with street map.
0.30074691772461 seconds processing time
