BIKELAND > FORUMS > ZX-14.com > Thread: Nitrous and petrol maps NEW TOPIC NEW POLL POST REPLY
Douglas Home
posted May 07, 2009 07:53 PM
Im thinking of using my window switch , solenoid activating wire to switch on my nitrous map automatically through a relay. . I have a PC3USB and hub with a dash mounted switch to manualy swap between two maps . I've heard that solid state relays switch faster than the traditional coil relays. Has anyone done this succesfully ? Does it shut the PC3USB down if switched on the moove ?Any tips on how to do this would be apreciated thanks.
Doug Mackay Australia
fury
posted May 08, 2009 02:17 AM
The relay is no issue.
I am hitting a dyno on Monday.
The description above is how my system works exactly.
It has been well over a year since I wired this unit up.
Who's hub are you using?
They come with a switch.
Change the switch to a relay.
Make the Arming Mechanism your HUB activation. (3 way toggle)
Left reg run. Middle disable the bike. Right Hub activation.
The setup works flawless.
Switch over of maps is instantaneous.
0.23264694213867 seconds processing time
