BIKELAND > FORUMS > ZX-14.com > Thread: Flies out map (stock pipe) NEW TOPIC NEW POLL POST REPLY
DaedalEVE
posted May 07, 2009 10:37 AM
Like the title said, I'm trying to find anyone with a flies out map using the stock pipes. Been looking on my own for the past week and am hitting dead ends at every turn.
08 ZX-14 (Silver), ASV Levers, Spiegler Lines, Spiegler/LSL Sliders, Flies Out, Marble Mod, PCV, Muzzy M14/M10 Full System
Wheelie
Old Man
posted May 07, 2009 10:55 AM
pc.com ?
wee
DaedalEVE
posted May 07, 2009 11:19 AM
I called DynoJet this morning and was told the stock US map they have is for 100% stock bikes (ie: secondary flies were not removed).
I just want to get those flies out and a PC on because I hate the idea of my bike being gimped like that. Obviously I'll be getting a full system at some point, but until I can afford it the flies and PC are the best I can do.
DaedalEVE
posted May 07, 2009 11:28 AM
I'm sorry, this is for an 08. Or would an 07 map work correctly? I'm not really sure how different the two years are.
JDC
posted May 07, 2009 01:27 PM        Edited By: JDC on 7 May 2009 21:28
Read a little on this. You should be able to get pretty close.
http://www.bikeland.org/board/viewthread.php?FID=27&TID=46821
You can close off the enrighment around 4.5 to 5 K, however since you have stock pipes, if you like.
DaedalEVE
posted May 07, 2009 01:46 PM
Thanks JDC!
So +10 % at 3400rpm is enough to compensate for the added flow? Good stuff.
Would it be better to start with the stock map or a zero map?
As things stand, the stock map (from 5%-100% throttle at 3500rpms) reads: +14, +13, -6, +3, -3, -5, -8. So would I change that to +24, +23, +4, +13, +7, +5, +2?
Either way, this has helped a LOT. Thank you!
0.29636311531067 seconds processing time
