BIKELAND > FORUMS > ZX-14.com > Thread: lowering options NEW TOPIC NEW POLL POST REPLY
dcjens
Wet side of Washington
posted May 04, 2009 09:57 AM
lowering options
I find myself roughed-in a little too close to the ground (5-9,10). I know there's a lot of lowering going on with the 14 and need some ideas on lowering the rear. I assume dropping the forks in the tripple trees? I do mostly street and twisties riding solo.(although gilberjj is trying to change that!) I'd feel more confident backing up and slow moving turns if I could touch the ground once in a awhile! I am concerned with handling and bike geometry. I weigh 165 wringing wet and rarely have a passenger as they complain about not being able to stay put. Any advice is appreciated, Darin
Black 06
posted May 04, 2009 10:34 AM
You can either get the lowering links that have 3 holes in them (muzzy is what I have) or you can spend a little more and get a set of adj lowering links than can be adjusted to any heigh desired. Depends on how much you want to spend.
0.2771852016449 seconds processing time
