BIKELAND > FORUMS > ZX-14.com > Thread: help stop this DAMN drain plug from leaking NEW TOPIC NEW POLL POST REPLY
06redzx14
posted May 04, 2009 07:39 AM
can't figure out how to stop my drain plug from leaking. it's a klems cut down pan, but it has the original plug and washer. i've tried
pipe tape- didn't work
rtv- didn't work
going to the part store to see what I can find, any suggestions?
posted May 04, 2009 07:41 AM
If the surfaces are clean, the bolt undamaged and the washer new...it definitely shouldn't leak!
hardatit
posted May 04, 2009 07:43 AM
my clems pan has a pipe coupling with a allen head type of set screw, no head on bolt. Haven't had any leaks. Do you have a crush washer behind it.
06redzx14
the washer isn't new. hopefully they'll have on in stock at the dealer. thanks
06redzx14
posted May 04, 2009 07:45 AM
this is one of their older pans before they started putting the allen head bolt in. does anyone know where I can find a bolt like that?
It still has a clean, flat surface for the gasket to mate to...right?
I haven't seen the setup on the clem's, but you need that flat surface to run an oem style plug/washer.
pazx14rider
posted May 04, 2009 07:49 AM
+1
06redzx14
posted May 04, 2009 08:00 AM
it does shane
ZXGRIFF
posted May 04, 2009 11:06 AM
Should replace the OEM washer after every oil change.
0.31991910934448 seconds processing time
