BIKELAND > FORUMS > ZX-14.com > Thread: engine cutting out? NEW TOPIC NEW POLL POST REPLY
Newbusa
posted May 02, 2009 01:25 PM
engine cutting out?
So first time out with the 14 and all the new mods,Took out the secondaries ,installed PC3 with map,Installed Brock pipe.Today was the first time i actually went to redline and on occasion it will act like it hits the rev limiter ,like it just goes flat.But it can be at 5 grand as well as higher up the rev scale.Almost like its starving for gas or hitting rev limiter.Yet other times i can give up to redline and fairly high speed and no problems.I am just wondering could this be because i grounded the PC to the frame as per instructions instead of negative on the battery?Confused!
posted May 02, 2009 01:28 PM
You probably have a bad ground with the PC3. Extend the ground wire over to the battery.
zxbob
posted May 02, 2009 01:56 PM
Grounding it to the frame is fine .... did you remove the paint first ?
Bob
posted May 02, 2009 02:02 PM        Edited By: Shane661 on 2 May 2009 22:09
Bob
So, does that mean that you agree that grounding is the likely issue?
There is a very good, solid ground coming off of the battery. I'm sure you can ground it elsewhere, though...but I know that one is 100%. I find it more convenient to have my electronics centrally grounded.
Newbusa
posted May 02, 2009 07:18 PM
I actually grounded it to the bolt that bolts the coolant tank to the engine.But i will try grounding to the battery.Thanks for the ideas guys.
gilberjj
Friend of Fast
posted May 02, 2009 07:19 PM
You can ground to the battery WITHOUT extending the ground wire. You just have to relocate the pcIII to under the seat....
posted May 02, 2009 07:20 PM
That's how I have mine right now. But that won't work if you add an ignition module...the cables are too short to mount it under the seat.
Newbusa
posted May 02, 2009 07:25 PM
I actually like it inside the front fairing.I barely have room under the seat for the tool kit and owners manual.
zxbob
posted May 02, 2009 07:28 PM
Bob
Pretty sure its a grounding issue ..... battery is the 100% sure fire ground.
Some people cannot extend the wire properly ~ so it may be easier to
remove the paint where the unit is to be grounded.
Bob
Douglas Home
posted May 02, 2009 07:45 PM
Mine was 5 ohms resistance from the coolant bolt to battery post ,
this was enough to cause me problems too. Ran an earth wire to the
battery earth bolt and soldered all my aftermarket earths to it / no more problems!
Doug Mackay Australia
Newbusa
posted May 03, 2009 09:54 PM
Well regrounded the PC3 not to the battery but just as good i think,I grounded to the bolt that the negative ground from the battery goes to.I put the wire right between both heavy cable grounds from the battery to what appears a frame ground behind the engine..It seemed easier then yanking the battery out.Now just have to go test.
0.24376797676086 seconds processing time
