BIKELAND > FORUMS > ZX-14.com > Thread: ninjaboy311 PMs are down NEW TOPIC NEW POLL POST REPLY
Seven
posted May 02, 2009 04:41 AM
I know you were running a tsukigi sidewinder on your bike before you switched to the muzzy system. I was thinking your old map would most likely be comparable to what im looking for. Tsukigi SW, no flies, K&N filter. Have been looking around but with no luck!!! Think you can help me out? Thanks Seven
project in the works!!! +4 mil stroker falicon rods CP pistons, APE valve springs, head studs, high pressure oil valve, muzzy HD oil pump plate, Adams performance 2" pan and Tsukigi sidewinder, lowered 2"
ninjaboy311
posted May 03, 2009 08:38 PM
I've run the exact same map with all 3 of the sidewinder's I've owned. As long as you have an 06-07 model, send me an email and I'll send you what I have.
pchabaud@cox.net
0.23780512809753 seconds processing time
