BIKELAND > FORUMS > ZX-14.com > Thread: back half MPH NEW TOPIC NEW POLL POST REPLY
06redzx14
posted April 27, 2009 07:12 AM
back half MPH
what does your 14 back half? mine has only been picking up 23-24 MPH. 1/8 mile MPH has been 116-117, but 1/4 MPH has been 140 for the last 2 weeks. my clutches are showing the stack height within the service limit. bike and me 765 lbs 17 psi shinko
16-45 gearing alien head
06redzx14
posted April 27, 2009 07:18 AM
posted April 27, 2009 07:28 AM        Edited By: Shane661 on 27 Apr 2009 15:29
Slip on left #44, M14 at your weight, 16/45 gearing, Shinko. Slip on right #58, 690 lbs, Shortmeg, 16/43:
About 27 mph.
posted April 27, 2009 07:46 AM
Depends on weight , temps, wind and track prep ... I range any from 27 MPH to 30 MPH..
Beondwacko
posted April 27, 2009 10:49 AM
In the 1/8, I regularly pull 115-116 mph, and in the 1/4 144 - almost 146mph.
At a scaled 775lbs (bike and all gear) I'm not complaining one bit !
kawasakijockey
posted April 27, 2009 11:29 AM
I'm telling you it's the Power Ranger suit holding you back.......It's Morphin' Time!
Put me on it this weekend and we can compare.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
kawasakijockey
posted April 27, 2009 11:35 AM
Even though I am about 60 pounds heavier than you, my mph in summer is 27 and 30 in winter.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
06redzx14
posted April 27, 2009 11:36 AM
that'll work, but be advised it may speed up your lockup decision. LOL! james and I have weighed in the same at the same track and his MPH pre-lockup was about 147 or so.
posted April 27, 2009 11:38 AM        Edited By: Shane661 on 27 Apr 2009 19:39
What is his mph now? I am going to be testing mine soon. The big issue is what gearing I run...I imagine I can't slide the clutch out as far with the lock up.
kawasakijockey
posted April 27, 2009 12:49 PM
The mph is down the crapper because I am trying to tune the lock-up using lighter than stock springs. The design is not aggressive at all and only holds at high rpm with the 7.5 grams weight it comes with. You should not have any clutch control issues. I dont want to hi-jack this thread with the lock-up stuff but if you want to start a discussion again we can start a thread or do PM's.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
0.22325205802917 seconds processing time
